Best buggy & truggy tire for packed clay?
I got a big indoor race coming next month (finally some racing!) and it's going to be a typical hard packed clay based indoor track. I've never raced an indoor race before so I've got no idea what usually works. So what kind of tires work best in this situation? I was thinking of the following tires:
So what do you indoor racers run on the clay hardpack? I'd really like to hear everyone's experiences with indoor tires. regards speed metal |
panther switch 2.0 and inside jobs - M3 though, not m2. Use stiff ofna foam (yellow?) with the switches and the stock foam with inside jobs.
1
We raced at the MidWest Nats. in Columbus. Panther Switch's in clay compound was,,,, OK. Pro-Line inside jobs had more side bite. The Losi drivers were using their new Taper Pin setup which looked awsome. If they are out, you may want to take a look at them.
Great replies guys! It's looking like Switches and Inside Jobs are getting the most recos. Has anyone tried Cell Blocks? What about Bow Ties? They're supposed to be good on clay too. Any experiences with these other tires? Or are the Switches and Inside Jobs the only way to go?
cell blocks wear out in 10 seconds. Stick with IJ's in M3 or switch 2.0's in Clay
OK thanks for that input o.s.power! Looks like Inside Jobs have the inside track :)
What about those new Holeshot MTR's for the truggy. The new PL MTR series of truggy tires look really good. Has anyone tried the PL Holeshot MTR's yet? Also is there no love for the GRP line of tires? Cubics look pretty good for this situation. Any thoughts or experiences? regards speed metal |
Whatever you do, do not get bow ties! You will slide all over the place.
Can't go wrong with holeshots on clay, the panther 2.0 are good but I think pink taper pins are better. Even try the pink king pin. Also, the inside job is a very good tire similar to the holeshots. I'd say go with the pink taper pin first, then holeshot second, panther 2.0, and a tie between inside job and the kingpin for fourth best. Got pictures of the track? |
Can't go wrong with holeshots on clay, the panther 2.0 are good but I think pink taper pins are better. Even try the pink king pin. Also, the inside job is a very good tire similar to the holeshots. I'd say go with the pink taper pin first, then holeshot second, panther 2.0, and a tie between inside job and the kingpin for fourth best. Got pictures of the track? Don't confuse the man now, 1/8 scale not 1/10 |
Can't go wrong with holeshots on clay, the panther 2.0 are good but I think pink taper pins are better. Even try the pink king pin. Also, the inside job is a very good tire similar to the holeshots. I'd say go with the pink taper pin first, then holeshot second, panther 2.0, and a tie between inside job and the kingpin for fourth best. Got pictures of the track? Great input everyone! I'm not any closer to decision but at least I'm getting a better idea at what's gona work and what's not. regards speed metal |
At the Pro Series Finals in Rockford this past year, the track was built the day before the event, and it was a clay based track...
Most people liked the Bowties or Crimefighters better than the inside jobs and switches surprisingly. By the end of the event on sunday there was so much traction layed down that Knuckles 2.0 in M2 compound was dialed.... I'm guessing this track might be the same if they don't water it, if they do, then it will probably be an Inside Job/Switch type of track, but thats just what i think anyway. so i'm pretty much gonna bring a little of everything, Knuckles, Bowties, Inside Jobs, Switches, and Holeshots (if they are available in time) |
Most people liked the Bowties or Crimefighters better than the inside jobs and switches surprisingly. By the end of the event on sunday there was so much traction layed down that Knuckles 2.0 in M2 compound was dialed.... I'm guessing this track might be the same if they don't water it, if they do, then it will probably be an Inside Job/Switch type of track, but thats just what i think anyway. so i'm pretty much gonna bring a little of everything, Knuckles, Bowties, Inside Jobs, Switches, and Holeshots (if they are available in time) Hey thanks a lot!! That was an awesome post. Very informative! BTW good to see you over here. I think Matt was saying they're gonna water it. Maybe I should find the post where he says that. I wish I could afford to buy a set off each. I'm just gonna collect them as the season goes on. :) Im trying to decide one one set for my buggy and one set for my truggy. I already have Crimefighter MT's and HPI Nubz for the truggy and GRP Jollies and Panther Komodo Dragon 2 in medium soft for the buggy. That's what I'm bringing plus whatever "clay" tires I pick for this race. Hopefully I pick well! regards speed metal |
