RECIEVER PACK CHARGING ADVICE
i HAVE A 1100 MAH RECIEVER PACK !!! HOW LONG WILL I HAVE TO CHARGE IT ON A OFNA 11OV CHARGER ?
HERE IS THE CHARGER http://www2.towerhobbies.com/cgi-bin...9&I=LXHCF1&P=K |
If it's empty, about 12 hours
iM NOT SURE IF ITS EMPTY DO THEY SHIP THEM EMPTY?
yes they do. get a fairly cheap peak charger and charge it at 1 amp for a few hours and then inbtween you heats and it will last you all day
OK thanks for all the advice!!! I kinda figured it had juice I had to modify my connectors to fit it!!! but thanks!!!
charging at 1 amp with a peak charger wont take a few hours. |
I use a peak charger @ 1.2 amps, and it only takes about 30 minutes if it's low.
Im just using the wall charger it lasts all day and I charge it over night!
On your new pack for the first charge you need to do a forming charge. Charge it for about 14 to 16 hours the first time with this wall wart charger. After that it will take about 8 to 10 hours (overnight). The forming charge is a critical step if you want the pack to last. I suggest that you look into getting an loaded voltmeter to keep a check on the voltage of the battery. Regular checks will help to lower the chances of a runaway do the the battery dumping.
So with the ofna wall charger !!! Charge it for 14 to 16 hours then run it?
Then charge it for 8 to 10 at night after discharged |
