Novarossi T21BF
I am told to only run Novarossi No.6 Standard glowplugs? How will a OS #8 do?
If its no good, what do i run as the nova plugs are hard to get here in australia.. :( Thanks :D :tire: |
it will work, a nova plug is longer than the os 8 but it wont cause you any problems from being shorter. you can also try the odonnell 99 if you can get them. it is a long plug and works well in the nova.
I run mc-9 in mine, {thats a Mccoy plug} best plug in my opinion for this motor.
Never liked os plugs in the nova motors stick to mc9 or a mc59(hot). They will work perfectly if you cant get a nova #6
I tend to use cooler plugs in mine, and they work out pretty well.
I don't think you want to be using a mc-59, thats a little hot, especially if you run 30%, if you are using 20% yeah you could use it in a pinch. When I had mine, I used OD 99 plugs with great success.
OD99 or nova 6.
