Old 02-14-2007, 03:58 PM   #1
Send a message via Yahoo to kurt777
Default setting up
Can i ask any one how do you set your car up properly
kurt777 is offline   Reply With Quote
Old 02-14-2007, 04:18 PM   #2
Trader Rating: 24 (100%+)
Depends on what car, what class, what surface, what track.
You can go to the manufacturer's website and download a setup sheet that resembles your track. Or you can ask the fast guy at your track how his car is setup.
The kit setup should be pretty decent while you get the hang of driving on a track. You can get tips from the local racers about what will make your car handle better and adjust from there.
I'm sure someone will link you to a suspension tuning guide (I don't know the links) which you can study on so you know what is supposed to do what. Just knowing is part of the battle, takes tons of time and practice to know when and what to change.
When I first started racing I always thought there was a magic setup that would make my car fly around the track like it was on rails. Never found that setup b/c it doesn't exist, and years later I'm still learning everytime I am at the track. What I mean is you can adjust till your fingers fall off but you still have to drive the car properly.
And now is when the more experianced racer says.."slow is fast."
That means drive only as fast as you can stay in control of your car.
Hope some of that helps
Team Associated & CRC, Trackstar motors/esc's, Spektrum radios.
Keeping racing fun and affordable with my 7 year olds :)
The best track I've raced is the one in my backyard!
jbrow1 is offline   Reply With Quote
Old 02-14-2007, 04:23 PM   #3
Originally Posted by jbrow1
.."slow is fast."
gatermaxx is offline   Reply With Quote
Old 02-14-2007, 04:32 PM   #4
Make one change at a time. Learn what one change does to the performance of your car before you move on to a different place.
Be willing to admit that a change wasn't the right one/not the right direction. If you try to keep a hurting car working, sometimes its better to start over with the setup.
have fun chasing the monkey
Team Associated, Reedy, LRP, Factory Team, Jconcepts, BFastRc, Darkside Designs, CRCRC.com, Dirt Burner Racing
DanGriffin is offline   Reply With Quote
car setting! jameslow Nitro On-Road 5 02-21-2008 06:59 AM
a little help setting up a M8 cyrrus Electric On-Road 3 06-16-2007 09:21 PM
Toe setting help Xrayskid Electric On-Road 10 06-12-2006 05:15 AM
Setting foe V One S xax Singapore R/C Racers 7 11-07-2002 05:44 PM
SEO by vBSEO 3.5.0
