Old 02-13-2007, 11:32 AM   #1
Send a message via AIM to brandonizr
13.5 and 7.5 gearing on the MF1 or MF2?
Looking for recommendations on gearing the brushless Novak 13.5 and 7.5 in the 1/10 MF1 or MF2 stadium truck...found a thread suggesting 2 teeth over a brushed, anyone out there with experience??
brandonizr is offline   Reply With Quote
Old 02-13-2007, 04:23 PM   #2
jgroenhof's Avatar
Default Oh no!
Not you too Brandon.
They're going over brushless gear ratios in the XXX-CR Forum.
Match-race? Zipper vs. Brandon... for pinks... Stand Back!
See ya this weekend!
Johnny G
jgroenhof is offline   Reply With Quote
Old 02-13-2007, 05:22 PM   #3
Here is a link to Team Novak's web site's PDF page of gearing suggestions for a 5.5 or 6.5: http://www.teamnovak.com/download/in...rg_gearing.pdf
With the 6.5 at either a 15 or 16 tooth pinion for a XXX-T that has the same tranny as the MF-1, I would guess a 16 or 17 tooth pinon for the 7.5 to start with.
Sorry, but I could not find the recommended gearing for the 13.5
Good luck!
Craps is offline   Reply With Quote
Old 02-13-2007, 08:07 PM   #4
sepirts's Avatar
for your 13.5, 2 teeth over your brushed is a good start. Last year I tested with a 7.5 for a little. And I used 15, 16, 17 and 18 teeth with the 7.5 depending on traction, track size and my mood. Ultimately, I settled for a 6.5 with 15/16 teeth. I have only used the 5.5 / 6.5 /7.5 with sintered rotors. I've used the 13.5 with both. The sintered is noticably quicker, even in the hands of the less experienced. (faster is not always better).
A 13.5 with Sintered rotor can easily pull 2 more teeth. On wide open tracks without much jumps, I've gone up to +4 teeth. But you have to be a really smooth driver (and I'm not).
sepirts is offline   Reply With Quote
Old 02-14-2007, 03:53 AM   #5
The sintered rotor in the Novak is a must have. It runs alot cooler and cooler means more gear can be run. We are using 5.5s with the sintered rotor in 20 minute races without the fan on the GTB ESC.
Gearing lickashotblaow Electric On-Road 0 07-29-2007 04:47 PM
NeeD Help with gearing please daver1 Electric On-Road 4 07-20-2007 08:12 AM
Gearing for TT-01 tl-01-jhb Rookie Zone 0 11-10-2004 04:35 AM
Need help gearing a TC3 fasda1 Electric On-Road 10 11-06-2004 10:51 AM
Gearing??? mike m Monster Trucks 3 01-24-2004 06:54 PM
SEO by vBSEO 3.5.0
