Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-31-2009, 02:33 PM   #6766
thanks mang.
BeefHead is offline   Reply With Quote
Old 10-31-2009, 02:37 PM   #6767
dgdcustoms's Avatar
Trader Rating: 46 (100%+)
Just remember that it doesnt come with any rubber.So you will need tires for it too.
KYOSHO RT5/Tekin RS/Fantom
KYOSHO RB5 SP/Tekin RS Pro/Fantom
KYOSHO ZX-5FS/Tekin RS Pro/Fantom
_____________________________________________
FantomRacing.com_DGDCustoms_BLOCK HEADS_XTREME HOBBIEZ_Team Slant EyEys
dgdcustoms is offline   Reply With Quote
Old 11-03-2009, 01:22 PM   #6768
j force jato's Avatar
Default ball diff
i just build the diff in my sp,like the instruction says
how tight should you tightin it?
i just rolled the gear till it got a little tight,then i tighted it abit bit more with a screw driver,im worried i dident snug it up enough
thanks
mohawk rcer :P
j force jato is offline   Reply With Quote
Old 11-03-2009, 02:13 PM   #6769
BenEllis's Avatar
j force jato- Hand tighten it a decent amount so that it is tight. You won't actually set it until it is in the car.
Once in the car, with tires and electronics ready to go, spin one of the tire, if tranny spins too feeley, its too loose, if it feels like it isn't free at all, loose it. You don't want it over tightened when you first break the diff in.
Once you have got a quick hand feel on loosness/tightness, turn the car on, hold one tire and slowly hit the throttle up to about 15%. Let the free tire spin for 20-30 secs. Then do the same to the other side. Once you have finished this, check how loose/tight the diff is again, more then likely you will tighten it slightly.
Then give it the track test, while driving, if it chirps, its too loose. Tighten in small amounts until the chirping stops. Make sure your not confusing what seems like a loose diff for a loose slipper.
-Ben Ellis
Team Kyosho / AKA / Team Orion / Big Horn Designs / TnT-FX Graphics / Peak Racing / Live-RC
BenEllis is offline   Reply With Quote
Old 11-03-2009, 04:33 PM   #6770
johnnyboy's Avatar
Trader Rating: 14 (94%+)
This is perfect advice. I do it the same way as well.
"Almost Live Race Coverage": www.johnnyboy.ca
.:Kyosho America : Peak Racing : JConcepts : JTP:.
johnnyboy is offline   Reply With Quote
Old 11-07-2009, 05:19 AM   #6771
kwiksi's Avatar
Send a message via AIM to kwiksi
Well after a summer with a diff buggy. I went ahead and put together a RB5SP. I raced one fall of last year into early spring before the switch. I missed that buggy so much.
Anyways I understand that everyone is using the narrow blocks in the rear. What about the shims that raise them?
David Perez
RB5SP - RT5
Team High Velocity - Evo Grafix
www.summitrcraceway.com - www.HighVelocityRacing.com
kwiksi is offline   Reply With Quote
Old 11-07-2009, 07:54 AM   #6772
Randy Caster's Avatar
Picked up an RB5SP last week and took it out to the track a couple times this week, gotta say I'm really impressed with the car. Little hard to drive mid corner/exit on the low speed corners but I think I have just what it needs. Gonna head back out to the track on Mon/Tues/Wed for more testing and racing.
Haven't broken a single part except a T-Plate which was from overtightening a screw on the pivot mount. The car is definately durable!
Tamiya TRF - Peak Racing - BMI Racing - KO Propo - AKA - Parma - Manutech - Slapmaster Tools - Pound It Paints
Old 11-07-2009, 09:04 AM   #6773
johnnyboy's Avatar
Just getting back from my little hiatus.
What is the current "hot" set up with the new rear blocks etc? Thanks guys
Old 11-07-2009, 09:21 AM   #6774
johnnyboy, I've been going between Tebo's crcrc setup for low grip and his HRH setup for high grip. Great starting points.
kwiksi, good to see your back on board! With the narrow blocks dont use any shims. Make sure to pick up some 54mm rear shock shafts too.
Team Kyosho/ Peak Racing/ AKA/ bkpaintwerks.net
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 11-07-2009, 09:40 AM   #6775
johnnyboy's Avatar
Yeah I figured those would be the way to go, but I didn't see any remarks on the set up sheets regarding the new rear block/shim options. Thanks
Old 11-07-2009, 10:43 AM   #6776
Slant EyEs's Avatar
Like what Rayls said, but most of us use the AL suspension mounts, so no shims under those as well.
Hey David, remember my K20'd Integra? 295hp to the ground on a bone stock bottom end.......
So where did you go? Somewhere fun I hope......
-Jayson Pang-
Kyosho America - Team Orion - KO Propo - Darkside Designs - J-Concepts - Red Bull - Diggity Designs - Speedtech R/C - Team Slant EyEs - KyoshoForum.com
Slant EyEs is offline   Reply With Quote
Old 11-07-2009, 11:06 AM   #6777
Just a question for those familiar with the different brand shock oils. I'm running AE 30 in front and 25 in the rear, but want to step the weight up a little bit. Was thinking about going to Losi 35 in front and 30 in rear since those oils run a little softer than AE from what I'm told. Is that about a half weight difference compared to using AE 35 and 30?
Old 11-07-2009, 11:59 AM   #6778
Slant EyEs's Avatar
Here you go Randy.
-Jayson Pang-
Old 11-07-2009, 12:16 PM   #6779
johnnyboy's Avatar
crazy 2 year old kid and crazy at work.....
just trying to get back up to speed on set ups.
Old 11-07-2009, 12:28 PM   #6780
kwiksi's Avatar
Damn! Nice way to represent the K-series.
Got the shafts Adam.
David Perez
RB5SP - RT5
Forum Jump
WTB a KYOSHO ULTIMA RB5 or FT B4 ttr_racer R/C Items: Wanted to Buy 4 01-30-2009 11:37 PM
Kyosho Ultima RB5 - NEW IN BOX truraza R/C Items: For Sale/Trade 18 09-13-2007 11:56 AM
kyosho ultima st jay111 R/C Items: For Sale/Trade 2 07-29-2005 08:25 AM
Kyosho Ultima ST jrighter R/C Items: For Sale/Trade 3 04-13-2004 05:20 AM
Kyosho ultima RB gulio R/C Items: For Sale/Trade 0 10-29-2003 03:09 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
