Orion Advantage ?????'s
And yes i looked in the manual...
Is there a volt cut-off on the discharge mode.....I want to set it at 5.6 and bring them down with my smart tray. For the life of me i cant find any info about it..... May have to sell it and buy an ICE that has that feature. Thanks :rolleyes: |
I haven't found a way to adjust it either, it does seem to cut off kinda high.
See!
Chris, that's why you need to buy a Dump Discharger, such as the one I tried to sell you Sunday at the track. Oh, never mind. Seriously though I think any real dumping duties would be better left to an inexpensive device, rather than a high end charger. Also you can handle your charge, and discharge duties at the same time.
I think the true purpose of the Orion discharge function is really for cycling. Hope you know I am really just thinking out loud here. The charger I got off Charlie, finally crapped out. I think 3 3800's back to back were a bit much for it. What do you think about the Orion? Other than discharging. I guess everybodies pretty happy with the ICE. Hopefully this is the right Chris, other wise you'll just think I'm crazy. See ya at the track Sunday? I got my race money this time. Have a good one. |
The Orion Advantage Charger discharges batteries down to 5.4 volts.
Joe
I guess what I was thinking... Do you use your charger as your primary discharging device?
Something else I have been thinking about. When people tray batteries there should be some voltage to work with. A tray wont bring voltage up. If a cell is at 0.8v prior to traying, and your set to equalize at 0.9v you will never get your match. If you set your Smart Tray to 0.8v It would work better with a 5.4v cutoff. I know you've been around the track a few times Joe. What do you think about this? |
Yes, I charge and discharge my batteries with an Advantage Charger. Its best to set your Novak Smart Tray to .9 That will give you the same cut-off as 5.4 but will equalizes your cells.
WOW
maybe I'm overthinking this a bit. huh.
Was just at novak with a bad smart tray and the replacement was bad also...
Charlie said to discharge to 5.6 no lower and then tray them he said if you discharge to 5.4 and then tray them it will not be a correct .9 on the tray.... off to buy a ice!!! Anyone want to buy a orion charger???? |
Just remember with IB's its only best to tray them right before you start charging. When storing them you want to put 1000 mah back into the batteries.
joe is correct... always remember to put 1000mah back into it if you do happen to discharge your ib's... i accidently didnt do that and they sat for 2 months and well the packs i didnt put charge back into you could tell they didnt feel the same as the ones i did. oops :ha:
Hey Chris
Here is you quote
Chris why don't you PM me and we can talk about it. My name is John :nod: |
Proud new owner
Now that I own the above Charger, I was wondering which settings are the best to use.
I read/looked at the .PDF manual online, it's more like a picture book than a manual. It tells me how but not why. I so far have charged at 6.0A/4mv cutoff with both GP3300's and IB3800's. I haven't used the temp feature, because I didn't get it setup in time, and cycling/discharging were quite confusing. There are so many features to this charger. What's a good performance/reliability charging routine, based on the Advantage charger. |
Hi John,
Charging at 6 amps is fine. I would just change your mv setting to 3 per cell. This allows the batteries to peak without getting soo hot. I will also be at SoCal on Wedesday if you have any other questions. Hope this helps, JP |
John boy.....
I will be there with the manual on wednesday..... Any ???? about it i can show u then ok.... Chris |
More Q's!
Getting the hang of the Charger now. I really like it. Thanks again Chris.
The motor run in feature is great. One question. It reports back the Amperage draw while running. For example I did 2.0v/200 secs. run in with 7.8 amps drawn. No load. Is the Amp draw a useful motor gauge, which can help with gearing and motor selection. Also a temp cutoff of 40' C is pretty easy to acheive. How hot should I let IB3800's get? How about GP3300's? Thanks for being there. |
