Old 01-10-2007, 03:17 PM   #1
Angry E-maxx 7 cell problem
I got an E-maxx for Christmas and just purchased two 7-cell battery packs to run in it. The problem is that when I plugged it in, there is no juice. To answer several obvious questions first ... I charged the batteries using a peak charger the night before (and they took the expected amount of time to charge), secondly there was a little life, in that the ESC would show green lights when the trigger was pulled full throttle, and blink green lights when full throttle in reverse. In addition, the steering worked and would respond, as did the shifting from 1st to 2nd gear, just no power to run the wheels.
I had just run the car on two 6-cell sticks, where it ran just fine to completion. Is there any "programming" that needs to be done to the ESC to take the 16.8 volts? Could the batteries themselves be bad? Any thoughts would be greatly appreciated. Thanks!
hasqual is offline   Reply With Quote
Old 01-10-2007, 03:35 PM   #2
streetracer745's Avatar
Send a message via AIM to streetracer745
an emaxx speed control can only take 14.4 volts. your 7 cells are useless in the truck. the speedo limits at 14.4 input volts. your trying to put too much power through it.
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 01-10-2007, 03:36 PM   #3
no programming needed, it's probably a dud ESC or an obvious problem we havent seen.
if you have a chance, get a real esc from an e-savage.
aussiebuddha is offline   Reply With Quote
New E Maxx EVX-2 problem sir miles Electric Off-Road 2 12-31-2007 12:00 AM
Problem with Cell Master raidvs Australian Racing 1 01-15-2007 12:22 AM
t-maxx problem lovecrime720 Monster Trucks 5 02-13-2006 10:50 AM
s-maxx problem? Smaxxblue Monster Trucks 3 05-08-2005 06:35 PM
Problem with my t-maxx BIGGERSTUFF Electric Off-Road 2 09-23-2003 12:25 PM
SEO by vBSEO 3.5.0
