Charger and battery ?????'s
Hey guys...QUICK ?
I have a orion advantage charger and some 3800's It(charger) has setting for 3600 and 4300 but no 3800 What should i use? 36 and be 200 low or let it peak on the 4300? later |
chris, I have the same charger, you should be able to change the capacity of the battery. Under the battery data setting, go to capacity and push enter, and change it to what you want, push enter again to save the setting. You should be good to go.
DUH should have R.T.F.M
Thanks Chris :) |
