Old 12-08-2006, 02:42 AM   #1
joelzy_91's Avatar
lrp speed controler
hey fellas
would it be allright if i put a 13 double in my car if the speed controller sais that you cant go past a 13 turn.
joelzy_91 is offline   Reply With Quote
Old 12-08-2006, 06:31 AM   #2
Doughty's Avatar
it would be pushing it a bit hard.
the 13 turn limit is a guide, the limiting factor is the amount of amps it can deal with, so if you run a 13 turn that is geared quite low and run on plain tarmac you might be OK, but if you over gear it and run through long grass then you will be pulling more amps and really pushing your luck.
its 'safer' to stay higher than the turn limit (higher as in more turns)
Chris Doughty - Team Durango - LRP - BETA Tires - Nibbo Design
Doughty is offline   Reply With Quote
Old 12-08-2006, 10:45 PM   #3
WheelNut's Avatar
Send a message via MSN to WheelNut
If your racing I would say no, especially is you run on a high grip track. If your bashing on low drag surfaces then I wouldn't hesitate to do it at all. Be careful with your gearing! Start conservatively.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 12-13-2006, 10:21 AM   #4
MustGoFaster's Avatar
The advice that has been posted is good.
What I would recommend is NOT running it for more than 5 mins. without a break. Also check the temperatures of the motor, ESC and batteries periodically.
MustGoFaster is offline   Reply With Quote
Speed controler evo8guy R/C Items: Wanted to Buy 7 05-29-2006 04:48 PM
GTB Speed Controler Trade for GTX WisRacr1 R/C Items: Wanted to Buy 4 02-01-2006 09:25 AM
WTB micro speed controler c3sworld R/C Items: Wanted to Buy 3 01-21-2006 06:59 PM
i need a good speed controler cheap MrLesac R/C Items: Wanted to Buy 6 08-26-2005 01:06 AM
what speed controler? pony klr Electric On-Road 4 01-09-2005 07:53 PM
SEO by vBSEO 3.5.0
