Old 11-14-2006, 03:29 PM   #1
Tech Legend
Cain's Avatar
Trader Rating: 205 (100%+)
Default Cold Weather Engine Breakin, need advice
I have a Sportwerks .21 Pro engine that I want to break in, but I am not sure if its advisable to do it in cold weather. We get around 40s to 50s right now.
Has anyone done this and has any advice on it?
< Durango DEX8, DESC410V2, DEX410V5>
< Team Associated RC10B6D>
Cain is online now   Reply With Quote
Old 11-14-2006, 03:36 PM   #2
I'd start 1 full turn out from the factory settings on both the top and bottom end needles. Always use a heat gun or hair dryer to preheat a new motor before starting, it will turn over ALOT easier. You can also wrap a piece of aluminum foil around the head to help hold in heat, it keeps the air from going thru the fins. You should be fine, 40deg is really not all that cold to be breaking in a motor.
RYAN BARNES is offline   Reply With Quote
Old 11-14-2006, 03:47 PM   #3
amain's Avatar
honstly just wate till next season you will save urslef lots of troubble
amain is offline   Reply With Quote
Best gripping tires for tc5, cold weather jms04081974 Electric On-Road 9 01-07-2008 04:07 PM
cold weather starting esdjc Onroad Nitro Engine Zone 5 09-17-2007 03:48 PM
Cold weather & Nitros Oasis Monster Trucks 13 12-17-2004 06:06 AM
What temperature do you run in cold weather(winter)? dino.tw Nitro On-Road 18 12-09-2003 02:35 PM
Cold weather glitching? fatdoggy Electric On-Road 4 10-19-2003 05:10 PM
SEO by vBSEO 3.5.0
