what can bend a slipper shaft?
I noticed a while ago that my newish xxx-t mf2's slipper shaft had a slight wobble to it at the end. It made the spur and pinion have a slighly tighter mesh for a span during rotation, so the wobble was making the spur off center a bit.
So, i replace the slipper shaft. i noticed in the old one that the piece with the allen head that comes pre-assembled into the top gear looked as if it was overtightened into the top gear. The new one was not like this. So i installed the new one, spun it around after assembly and noticed the wobble had improved greatly. The spur 'seemed' to not be off-center as it was before.
well, i went for a run, just a parking lot bash session, come back, and it seems this slipper shaft is now making the spur do what it did with the old one. The end of the slipper shaft seems to be off center a bit and the spur as well if looking at the face of the spur.
these are things i know it's not-
-the bearings supporting the slipper shaft/top gear. These are mint.
-the spur. it is perfectly round in relation to it's center. i know this because before i ran it post-new shaft installation, it was rotating with no perceived off-center attitude.
-the hex head threaded shaft being loose- that shaft is thread locked and tightened into the top gear assembly. it is not going anywhere.
-the slipper pads. they are aligned properly on the spur.
what could make this happen and, is this common? Id like someone to look at their slipper shaft from the top of the tranny and see if it has a wobble to it and/or look at the face of the spur while slowly spinning a wheel to see if it has some sort of slight off-center behavior. i can't imagine what would make this happen, but maybe it's normal.
thanks.
