Beginner Truggie
Beginner Truggie
I currently run on road once or twice a month. oval and at tamiya.
I am new to off road and am seriously thinking about the new Kyosho rtr 1/8 Truggie to begin with. I have read and heard good things about this Truggie. Is this a good car to start with? comes with fm radio and engine by OS for all for $400. sound good!!!
Any other suggestions? I have heard that the better truggies are, Kyosho, Mugen and that Xray will have one soon.
thanks
wn
thanks
wn
Depending on how much you want to spend and what equipment you have, the Jamming X1-CRT truggy is a very good truggy to consider.
I just bought the Kyosho ST US and as a long time RCer and racer all I can say is that this may be the best RTR I have ever seen. The build quality is excellent. I changed the diff grease for diff oil (10/20/3 f/c/r) right away also to check screws. All the screws were snug and the shocks were filled.
The radio is an AM 27MHz but is an exception one for an RTR. It is an Airtronics 12 model memory with computer set up. Very similar to the MX3 FM radio. Since I have several minis using 27MHz it was a no-brainer to use the radio with those. I use a Futaba 3PK with Spektrum so naturally I swapped out the radio and I had a couple digital servos sitting around so I swapped those out as well.
I very pleased with the handling but it definitely needs sway bars front and rear.
Super Moderator
Location: Singapore ̡͌ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡V
Trader Rating: 76 (100%+)
The new Team VTX-ST1 1/8 4wd nitro truggy rtr looks really good too..a nice price to boot too...check it out
Team VTX Homepage
Team VTX Homepage
Tech Legend
I would make sure and ask those who have owned the truggy rtr version what they needed right away to correct issues with it. From what I have read, the Jammin CRT RTR has had some issues with flex that required changing out some of the parts right away to correct the issue.
Whatever you go with, its a good idea to give it an initial teardown and rebuild. You get to know how it goes together, as well as correct anything the factory missed (like loctite).
losi muggy
i have the muggy and it is awesome very quick and reliable it is great for club racing and parts are easy to find
Team VTX Homepage
Team VTX Homepage
Great prices, looks good.. but what about parts support? Anyone run these? I would look at these if I knew you could get parts easily. Build looks decent.
Thanks all for the advice.
the VT is probably out of the question, there are no hs in southern cal to support it.
I am leaning toward the Kyosh, except they are having issues regarding supplying the lhs with parts. th has pulled all kits and parts from normal list of kits and parts.
I hear the losi is good too. they are local and that is a potential source.
my lh sells the HPI hellfire, any body run this Truggy?
I am open to any an all suggestions including buying and building a 1st rate truggy.
thanks again you are all great!
wn
wn
Since you race on-road, I assume you already have a decent radio.
I would pick up the Mugen MBX5T truggy. It comes with good tires and does not need any upgrades. It's extremely durable. You'll learn more from building the kit (which goes together very nicely). For a motor, pick up a 3-port Novarossi 21BF ($165 shipped online) and a 086 exhaust. Then grab two decent servos. You'll be MUCH more happier in the end than buying any of the RTR kits. Plus the support from Mugen and the Mugen team is top-notch.
Best of luck...
Tony P.
Best of luck...
Tony P.
you must have been reading my mind,
I have been researching the truggies and have been very impressed with the Mugen MBX5t. nice quality and workmanship!!
thanks for the infor on motor and pipe suggestions, cuz i was just wondering what motor/pipe combo would be a good choice! LOL. I was even leaning toward a 3 port engine basing from my experience with .12 3 port engines vs. 5 port engines.
cheers
wn
cheers
wn
Tony P.
Is the difference between the MBXT 5 and the Prospect worth the extra bucks? I imagine I would be needing titanium turn buckles and some chassis braces.
thanks
wayne
thanks
wayne
