xxxt socal setup help
i was wondering if anyone has a good xxxt setup for socal rc raceway. thanks-mike
Try out Matt Fransis new standard set-up and work from there.
try
front-
#56 pistons with 27.5 wt oil and orange springs
shock mounted in the middle on arm and 2nd out ofrm the top
camberlink is stock (the middle on both) with 1 washer
rear-
#56 piston with 25 wt oil (27.5 when the track is new and smooth) with pink springs
as far as the shock location and camber link i havent realy moved it from the standard set up
tires- 8 row with stock foam in front
and hole shots or pink t-2000's with bomb 1 foam
i used the t-2000's tonight and as long as i stayed in the grove i was fine but when i got out of it to pass the truck got squirly on me. hope this helps i know i got a lot of help from the local racers at the track.
front-
rear-
thanks ill try that. hey what r u gearing youre xxxt? im running i think the stock spur for the mf is 88 or whatvever it is with a 22 pinion and i blew my mvp. what r u running?
im running a orion core stock, im still playing with the gearing and ive been running a 16 or 17 with the stock red gear, i dont know what the number of teath is on that gear. i havent used a mvp in my truck but i thought i read once that a mvp and core are very close to each other.
