Team Orion Advantage Charger? >
Old 08-31-2006, 10:53 AM
gman10's Avatar
Default Team Orion Advantage Charger?
I recently purchased a Team Orion Advantage charger, and was looking for some input on settings. I'm charging 3800 NimH batteries. I have been using the normal charge mode and it appears the charger automatically stops when it reaches 3800mh. My Reedy Quasar Pro would charge until it detected a peak usually over 4000mh. I know there are other charging modes, I'm just not too sure how they work. Any help would be greatly appreciated. Thanks!
gman10 is offline
Old 08-31-2006, 10:57 AM
Rick Hohwart's Avatar
Set the capacity higher than the cell capacity. 3800s will be fine with the charger set at 4500. With this setitng they will shut off when they peak rather than at the stated capacity.
Rick Hohwart is offline
Old 08-31-2006, 11:49 AM
Joe Pillars's Avatar
When charging IB3800 batteries on the Team Orion Advantage Charger set the charger to Ni-Mh.
Then like Rick said, set the Mah Capacity to more than the label on the battery. I always set my charger to 5000.
Lastly, leave the charger mv/setting at 3mv/cell. This is what it comes stock from the factory.
Setting the mah capacity higher on the charger will allow the batteries to peak off when they reach 3mv/cell.
Hope this helps,
JP
Joe Pillars is offline
Old 08-31-2006, 05:26 PM
gman10's Avatar
Thanks for the help guys. The battery seems to be taking a better charge now. One other question, I have head that the step charging mode is the best. Is this true and how does it work? Thanks Again.
gman10 is offline
Old 09-01-2006, 12:54 AM
scottk's Avatar
Trader Rating: 72 (96%+)
step charging is the way to go with gp's but a linear (normal) is the best option for ib's. Hope this helps.
cheers
Scotty
scottk is offline
Old 09-01-2006, 06:48 AM
Charge your IBs at 5 amps linear and you will get the best results.
Old 09-01-2006, 10:00 AM
gman10's Avatar
Thanks again for the help.
gman10 is offline
Old 09-02-2006, 06:51 PM
Trader Rating: 29 (100%+)
hi joe or rick
do you have any setup sheet for charger on website ??
if i have two charger what kind power supply ??
thanks tommy
taztal3 is offline
Old 09-03-2006, 12:17 AM
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by taztal3
hi joe or rick
thanks tommy
As for power supply, anything 12v, for 2 chargers (charging @ 5amps) a 10+ amp power supply should cover it. I would suggest getting some buffer though as the more the merrier. ie, you could want to add a motor checker later on or something like that. I also highly suggest Rivergate power supplies. I bought a 30amp Rivergate Bulldog over 3 years ago, never an issue (I race like 3 times a week), and I know many people who have had Rivergates for 10-15+ years without any issues. Just my .02
Frank Root is offline
Old 09-03-2006, 01:23 AM
http://www.teamorion.com/FAQ/Advantage
you can find whatyou need here
hi joe or rick
thanks tommy
barclayrc is offline
Old 09-05-2006, 10:27 AM
hi triptheat
where you get those rivergate bulldog power supply ??
thank tommy
taztal3 is offline
Old 09-05-2006, 10:33 AM
TLRacing
Frank Root's Avatar
hi triptheat
thank tommy
I ordered mine through my LHS. They are available through Horizon Hobby and any hobby shop worth its salt has a Horizon Account.
http://www.horizonhobby.com/Search/D...vergate&CatId=
Old 09-05-2006, 11:59 AM
hi triptheat
i have a 12v distribution box .
if i can run three charger and motor checker ???
i have team orion 3300 gp2 and 4300 battery pack
thank tommy
taztal3 is offline
Old 09-05-2006, 12:32 PM
TLRacing
Frank Root's Avatar
hi triptheat
thank tommy
Yeah, not a problem. I have run 4 chargers and a motor check at once without issues at all.
Old 09-30-2006, 07:32 PM
hi
i just buy a team orion 4300 battery packs. what good setting up ?
thank tommy
taztal3 is offline
