Old 09-21-2006, 01:06 AM   #16
downunder23's Avatar
ok cool i did the pinch test at the track and it did get faster and it died in about 6 seconds i think i got the tune right if you ask me thanks for your help.
the loading up on idle you say is right that makes me feel compfortable with it thanks. least it didnt die earlyer than the 4-5 seconds mark so it must mean its not to lean which is the main thing im worried about so job done i say.thanks thanks thanks guys well done.
downunder23 is offline   Reply With Quote
Old 10-02-2006, 06:51 AM   #17
Originally Posted by AreCee
Not really. An engine running lean will not have good performance. A properly tuned engine will be in between 210 to 290 F (99 to143 C) and optimally it will be around 250 F +/- 20 (120 +/- 6 C). It all depends on the engine, air temperature, track conditions, driving style, fuel, glow plug, etc. so you can see there are many variables to consider. Therefore if it preforms well, exhibits a smoke trail on acceleration and doesn't load up or bog down then you're in the right range.
u r right on! my .21 RB WS7 1 runs around 250F +/- sometime i push it to 280F. this engine is sweet on idle... those deep sond is sooo nice. The problem is, it takes longer time to warm up on first run. temperture will hoover around 190F for 1st half tank and the buggys run some what sluggish but when the engine warms up to 200F it's power pack.
I agree not to tune on temperature but i strongly believe that the temperature reading serve as a guide as to how far you can push the engine before it Kaboom!
stonely0 is offline   Reply With Quote
Engine temperature steponit! Malaysian R/C Racers 27 12-14-2006 12:50 AM
Checking Engine Temperature gavinmetcalfe Electric Off-Road 5 03-31-2005 09:14 AM
Engine Temperature adsl Onroad Nitro Engine Zone 2 11-24-2004 09:02 AM
Engine Temperature CHANGES with fuel level? gonsped Nitro On-Road 7 01-04-2004 09:08 AM
Tuning Engine *temperature drive4fun Nitro On-Road 21 05-24-2003 10:13 AM
SEO by vBSEO 3.5.0
