weird reaction BK2 with spektrum
my set up
BK2 with lrp v7.1 IB4200 DX3
for some odd ball reason if i steer more then 3/4 of the steering travel
the buggy will slow down and act like a dead battery
as soon as i let of the steering the buggy takes off and runs fine
but any time i steer more then the radio seems to want me to i get a real slow stutter
tried everything i can think of
even used another radio the problem wasnt there with my ex1
not sure on the version of software thats on it
but i did take this radio and receiver out of my T4 it ran fine with a novak 7.5 and gtb esc
has anyone had this problem before
starting to go nuts here
any advice would be great
thanks in advance
thanks in advance
im betting the fail safe is kicking in you may need to send in the rx i think they made some sort of dieode for the rx for problems like that.
i do not know if this is your problem or not, but a friend and i both where using specktrum,when i started having some of the same problems as you describe. at first the tech help said it was the motor, got new motor, still had problem, then it was esc, got new esc, still had problem, then sent rx's in and returned, still had problem, the last time i was the talking to some higher tech. the problem according to him was the group of things, stock motor, Q2 esc, jr9000s servo, high traction, causing a voltage drop. the fix is a 5.99 capacitor that spektrum sells. never had a problem again. that was in my stock bk2, stock mf2
this may help??
i still race.
this may help??
i still race.
