good motor for use in 4wd buggy and 2wd buggy
#16
associated has a sale on it's motors. I like the kr versions for buggy.
http://www.teamassociated.com/misc/i...t_specials.htm
http://www.teamassociated.com/misc/ReedyMotorSale.htm
#17
well looking at the choices i might go with an 11X2 or 11X3 checkpoint or a 19t money checkpoint. im going to see how the 19t guys do at my track before i decide. any tuning advice such as timing
Matt
Matt
#18
An 11x3 checkpoint is way to much for a 2wd unless your track is HUGE. You probably should get two different motors and 4wd likes lower turns while 2wd likes higher turns.
#19
You could use a 12x2 checkpoint in both if you had to. The 12x2 would be good in a 2wd. It is best if you can spare to money to get motors for each car. It is going to get old switching out the motors all the time. The Checkpoint motors claim of lasting 40 runs before needing rebuild is true. This does not apply to the 19T Money motor though. It uses different brushes and will only last 10 to 15 runs. The checkpoint mod motors are real screamers. I would go with a 12x2 in the 2wd and a 10x2 in the 4wd.
#20
yea i think ill just get 2 motors i have a junker 15t that ill put in the 2wd untill i get a better motor for it.
Matt
Matt
#22
Checkpoint Money is awesome... I run one in both my 2WD and 4WD and have plenty of power. The best thing about the 19T is u have the torque needed to get a 4WD rolling - and the speed for a 2WD depending on how you gear your car.
I originally bought the motor becasue I loved the idea of getting 20 runs on a set of brushes - after running it against guys that have 12-turn motors in their cars, I can say that the motor is not a disappointment at all.
#24
lol, brushless would be my favorite option but being 16 and not being allowed to get a job money is tight.
Matt
Matt
#25
I have Orion SV2 12 double on my sbv2 buggy...
Is V2 economic motor.
#26
well i think ive decided to go with a 12X3 or 12X2 checkpoint. now to get the $ to but it
Matt
Matt
#28
ill most likley be running a GTX esc. and smooth is an understatment. i ran a mamba 8000 in a mini-t with a 3 cell lipo. geared with the stock spur and a 16t pinion you couldnt give full throttle or you would flip!!! got to the point where i could keep the front down doing speed runs and could even do a controlled wheelie!
Matt
Matt
#29
checkpoint 12 turn mod. youll get about 40 runs out of it. lots of power too.
