Old 09-07-2006, 02:45 AM   #1
downunder23's Avatar
Default superchargers how they effect an engine??
hi ive been looking at these superchargers and am just wondering how they effect efficiency of the engine.
does anyone experienced know how they effect an engine in regards to fuel/air mixture do they cause to less of a fuel to air mixture resulting in low lubrication which causes engine wear?
and how does the fuel pressure valve effect efficiency/performance does more fuel pressure result in better efficiency and/or how does this work?
any opinions/experiences in regards to these superchargers?
i basically want to know the principles and dynamics behind how they effect an engine.. thanks.
downunder23 is offline   Reply With Quote
Old 09-07-2006, 06:10 AM   #2
Those are very effective in removing money from your wallet. But they sure do look cool.
Basically all a supercharger does is to charge more air, and with that more fuel, into the engine than it would normally take in giving more power since it's burning more air/fuel mix.
Now think how your model two stroke engine works. The air/fuel is pulled into the crankcase and then the pressure from the piston coming down forces the mix into the intake ports and at the same time opens up the exhaust port. The incoming mix forces the burnt gases out the exhaust port. That's the timing of a model 2 stroke. A supercharger would end up pushing out the unburned mix with the burned gases and you would have about the same amount of mix in the chamber as you would without the supercharger.
AreCee is offline   Reply With Quote
Old 09-07-2006, 10:31 PM   #3
they don't actually work on a rc vehicle. There are way too many variables that they forget about when it comes to 2 strokes.
Kemo is offline   Reply With Quote
Do these superchargers really work? z28mccrory Nitro Off-Road 13 12-21-2007 08:27 PM
2 Stroke Superchargers ? Havago Racing Australian Racing 14 02-09-2007 02:36 AM
is there any air filters that work like superchargers? downunder23 Electric Off-Road 2 09-07-2006 10:39 PM
RB Innovations Superchargers phillyfan5420 Monster Trucks 12 02-28-2006 06:49 PM
Do the SuperChargers work? DR.FeelGood Onroad Nitro Engine Zone 2 03-07-2005 08:22 PM
SEO by vBSEO 3.5.0
