Old 08-23-2006, 07:09 AM   #1
Bwadd2002's Avatar
Trader Rating: 8 (90%+)
Send a message via Yahoo to Bwadd2002
Default Orion Advantage or LRP Pulsar???
Looking to pick up a second hand charger/motor run in for my lathe. That is the main reason really for buying it, I currently use a pitbull for charging only and used to use a 4-cell pack for my lathe, but i want to get a charger that has the run in feature so that i can break the motors in after and run the lathe better.
So what is everyone's opinion on these two?? which on is better, what features are better and why?? Thanks all!!
Bwadd2002 is offline   Reply With Quote
Old 08-23-2006, 07:53 AM   #2
Tubaboy's Avatar
I use the LRP Competition 2. (Like you my other charger is a Pitbull)
Things I like about the LRP are:
3 Profiles... I like it for as the day temps heat up, I can just go to my next profile to keep my batteries from overheating.
Can adjust the charging rate on the fly.
If there is a power bump it yells at you. In addition, for extended power bumps it will tell you how long the power was out, so in case you weren't at your pits, you can increase the charging rate if necessary.
Motor run in smoothly ramps up to the voltage level. Gives you an AMPs report which is nice when breaking in new brushes to help you see when they're seated.
It's small. The thing barely takes up any pitspace.
Readout is easy to see and gives you good info.
The power connectors (going to power supply) can be removed for those of you that have jacks and don't need to clip it to something without you having to rewire the connectors.
Things I don't like
When discharing, the charger can only handle about 1 battery per hour cuz it'll get above 150*. I have 2 small 12VDC fans that I mounted on the sides to help cool it down. It has a fan inside, but it just doesn't get the job done. My little fans keep it from going above 80* during a discharge cycle.
Can't name the profiles.
Hope this helps you out. Either way, you will be happy me thinks.
www.wyomingrc.com | www.wyomingmodelerspark.com
Tubaboy is offline   Reply With Quote
Old 08-23-2006, 02:39 PM   #3
Sluggo's Avatar
Send a message via AIM to Sluggo Send a message via MSN to Sluggo Send a message via Yahoo to Sluggo
I have both chargers and you can't go wrong with either one.
Sluggo is offline   Reply With Quote
Old 08-23-2006, 08:52 PM   #4
Default orion
the advantage has three profiles also plus the new one also can charge lipos. plus the step charge system is amazing in what you get out of your batteries. it has a temp sensor to keep from overheating. in the past i used lrp's and had three blow out and have had two friends also blow out their chargers. i have also had troubles with quantum pro too. just real bad luck for me with anything from lrp. plus the orion will discharge at up to 10 amps. if your not using a smart tray. but the directions are a bit tough for it, but on orions site you can find the setting the factory drivers are using.
good luck but i votre orion for sure, so many features over the lrp and as i said step charge is unreal.
octane3117 is offline   Reply With Quote
Old 08-25-2006, 06:50 AM   #5
gman10's Avatar
I just purchased an Orion Advantae charger, I was curious where I could find the factory drivers setting on their website.
gman10 is offline   Reply With Quote
Pulsar 2/Orion advantage JeromeB R/C Items: Wanted to Buy 1 06-04-2007 01:31 PM
Orion Advantage or Pulsar! losirunner Electric Off-Road 9 11-26-2005 10:50 PM
Pulsar Competition, Orion Advantage, or Duratrax ICE killer89 R/C Items: Wanted to Buy 6 11-13-2005 08:52 AM
Pulsar Comp or Orion Advantage Sushi Man R/C Items: Wanted to Buy 11 10-19-2005 03:25 PM
Pulsar, Orion advantage or Duratrax Ice nordheim R/C Items: Wanted to Buy 3 09-06-2005 09:15 PM
SEO by vBSEO 3.5.0
