Old 08-15-2006, 11:15 PM   #1
downunder23's Avatar
Default sleeve stuck in engine plz help?
hi i have a .21 nitro engine which im planning on getting repinched for more compression but i have to remove the piston and sleeve to get it done and i cant get the sleeve out from the engine anyone encountered this problem before? and how did you get it out?
or anyone who knows how to remove it safely without ruining the engine ,piston or sleeve any help is much appreciated thanks.
downunder23 is offline   Reply With Quote
Old 08-15-2006, 11:28 PM   #2
Truggy1's Avatar
Heat up your oven at home to 350 and stick the motor in there for about 5 to 10 min take it out and use the eraser end and push slowly out the top.
Hope this helps.
Truggy1 is offline   Reply With Quote
Old 08-23-2006, 09:30 PM   #3
Default engines
be sure to remove piston and rod first before you try to remove the sleeve.
good luck
octane3117 is offline   Reply With Quote
Old 08-24-2006, 12:21 AM   #4
KK-racing's Avatar
good luck
You can't remove the piston & con-rod without taking out the liner first.
Or is there a way ??.
What I normally do is push it up with a nylon rod from below after removing backplate. If it refuses to barge, tap the nylon rod lightly till it start to move. It should move unless the engine has been shelfed for a long period of time without any after-run oil applied.
Do 'IT', with a DUREX (safely) !!!
KK-racing is offline   Reply With Quote
Old 08-24-2006, 01:29 AM   #5
we usually use a toothbrush for pushing the sleeve out. Just put the flat edge against the sleeve and the head against the table and push down, pops right out. How the heck would you get the piston out before the sleeve was out? And for the baking suggestion, be carefull banging it around or your bearings will fall out as well.
gatermaxx is offline   Reply With Quote
Old 08-24-2006, 03:17 AM   #6
I normally just stick a piece of tie strap, from the top thru the exhaust port and turn the flywheel. if its really stuck, I use a thicker plastic like a servo horn or a shock spacer. If that doesnt work i spray a little wd40 around the sleeve and let it sit. A little heat around the sleeve should help as well.
Genius is offline   Reply With Quote
Stuck sleeve....help.......... Taylorm Onroad Nitro Engine Zone 7 12-03-2007 05:13 AM
Stuck Sleeve Genius Nitro On-Road 7 10-17-2005 09:05 AM
Stuck sleeve....tricks??? NitroOB4You Onroad Nitro Engine Zone 3 08-23-2005 01:40 PM
Need Help with Stuck Sleeve!!! serpentsixty9 Onroad Nitro Engine Zone 10 07-25-2004 07:26 PM
carberator stuck on engine fasteddie d Onroad Nitro Engine Zone 6 01-05-2004 11:37 PM
SEO by vBSEO 3.5.0
