Old 08-14-2006, 02:31 AM   #1
Default Charger Power Supply
I am looking at buying a power supply and it says this in the description "instead of putting out 13.8V as per its design it puts out16.2V on a multi-meter straight on to the terminals".
Can someone tell me if this will make a difference to my charger ( Swallow Advance )? Is the voltage too high? Its 20amp.
rusty_dagger is offline   Reply With Quote
Old 08-14-2006, 04:05 AM   #2
does sound a bit to high i mean most things are rated to 15v but id never go higher than 14v imo
Josh P
to make Keith happy
Corally phi
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 08-14-2006, 07:11 AM   #3
SpeedBump57's Avatar
IMO that is high. I wouldn't plug any of my stuff into it at 16+
SpeedBump57 is offline   Reply With Quote
Old 08-14-2006, 11:27 AM   #4
i have a triton and im lookin for power too. I saw a guy using a triton with a novak black box. he made some connectors for it and he pluged it into an out let. what is a good cheap power supply i could use for that?
csdonnie is offline   Reply With Quote
Old 08-14-2006, 02:27 PM   #5
I would make sure the multimeter is accurate. Maybe check it again with another meter.
ddcarter3 is offline   Reply With Quote
Old 08-14-2006, 04:04 PM   #6
Trader Rating: 14 (100%+)
be careful with that high of voltage, just about all chargers can only handle 15 volts max. Look for a charger that has good amp output, at least 10 amps.
o.s. power is offline   Reply With Quote
Old 08-14-2006, 06:07 PM   #7
gman10's Avatar
I currently have a Bulldog 30 amp power supply which works great. It is just a little big and bulky to take to the track. What is a good smaller power supply that will run 2 Team Orion advantage chargers.
gman10 is offline   Reply With Quote
Old 08-15-2006, 12:28 AM   #8
Trader Rating: 32 (100%+)
I have an idea that the swallow advance will show error just like the triton does when 15 volts+ is applied to it.
gulio is offline   Reply With Quote
FS: Duratrax ICE Charger, Great Planes Triton Charger, & MRC Power Supply wrxnfx R/C Items: For Sale/Trade 15 08-20-2008 10:33 AM
Computer power supply used for charger power supply? 66Racer Radio and Electronics 7 05-24-2008 11:52 PM
Use linear DC power supply as a charger instead of buying another charger? potatonet Radio and Electronics 4 01-29-2008 03:50 PM
ice charger and power supply drywallgod R/C Items: For Sale/Trade 4 02-05-2007 03:46 PM
Novak Millenium Pro charger ans N- Power power supply RobertF R/C Items: For Sale/Trade 11 11-27-2005 07:59 PM
SEO by vBSEO 3.5.0
