Pro4 Motors $134.95
Old 08-11-2006, 04:19 AM   #1
Ron_J's Avatar
Trader Rating: 18 (100%+)
Default 3-5-7 port buggy engines?
In a buggy engine is there any distinct advantage or disadvantage to the the different port configurations? Why 3/5 or 7?
Ron_J is offline   Reply With Quote
Old 08-11-2006, 05:22 AM   #2
tex1's Avatar
Send a message via Yahoo to tex1
3 ports are efficient, and don't produce as much power. When used correctly this motor is very good on tight or slick tracks. You can push max run times to gain an extra advantage.
5 ports give more power in all ranges. They are easy to tune and just have a little less efficency than the 3 port. Usually a little more expensive as well.
Some of the most popular motors are 5 ports. P-5 Novas.
7 ports are very strong. They are good on big tracks where sraight away speed can give you a few positions in a heat. Large jumps are a breeze if you have room to stretch the legs of a 7 port. You will give up fuel though.
You want to go 7 port when you have max traction. These motors are usually the highest priced.
Indy RC World
T&T RC Cars - Plano, TX
RC America
Xray - Hudy
tex1 is offline   Reply With Quote
Old 08-11-2006, 05:29 AM   #3
T. Thomas's Avatar
Along with what tex1 stated, ports in nitro engines are also similar to windings in electric motors, ie single double triple, in where the power is delivered. A 3 port will have more power in the lower RPM range(fells like having more acceleration from a stand still, but no top end speed at all), a 5 port wil move the power to the middle of its RPM range(probably best all around choice for offroad), and a 7 port will have most of its power up in the RPM range(feel soft in the lower RPMS).
T. Thomas is offline   Reply With Quote
Old 08-11-2006, 05:30 AM   #4
Ron_J's Avatar
Great info! That's exactly what I was looking for.
Ron
Old 08-11-2006, 05:47 AM   #5
Davidka's Avatar
Trader Rating: 49 (100%+)
A multi port engine *should* have more top and usually do but don't forget, the OS V-spec is a 3 port engine and is one of the fastest engines you can buy from top to bottom. Those are good guidelines but there are always exceptions to the rule.
Old 08-11-2006, 06:17 AM   #6
TMizzle's Avatar
exactly... just when you think it makes sense... The V-spec shows up.
Its a 3 port and will murder almost every other engine all over the track.
At Nationals, 1st 2nd and 3rd ran Vspecs.
TMizzle is offline   Reply With Quote
Old 08-11-2006, 11:03 PM   #7
WheelNut's Avatar
Send a message via MSN to WheelNut
The idea is with more ports that the fuel can be "shot" into the combustion chamber more accurately than with less larger ports. So an engine with more ports should run cleaner and make more power than an engine with less ports. There are so many factors that play into the performance of a nitro engine though that the number of ports is just another feature of the engine, the dyno or on track results tell the whole story.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 08-11-2006, 11:39 PM   #8
BringItOn's Avatar
vspec is just about the perfect buggy engine. awesome powerband from bottom to top. awesome fuel economy. and is one of the cheapest to buy high performance engines going around. finally its getting the respect it deserves.
BringItOn is offline   Reply With Quote
Old 08-13-2006, 07:17 PM   #9
Z_Schneider's Avatar
It really doesnt matter as long as you buy a quality engine. Usually more ports mean harder tuning. You will be safe buying almost any Novarossi based .21 (RB, Max, Top, Rex,ect..) Tuning should be easy on any of those as long as you break it in properly. V-specs are good too, but I've seen some bearing problems lately. That is fixed when you put a ceramic in, then they last 4ever.
~X-ray 808-'10~X-ray XT8-'09~Associated SC10~Kyosho RB5
Sponsors:
~JConcepts~CPR Adrenaline~Shellz custom painting(me)~Team Dirtheaven~
Z_Schneider is offline   Reply With Quote
Picco 12 3 port engines and one piece pipes royfan33 R/C Items: For Sale/Trade 11 03-07-2007 07:01 PM
difference between 3 and 5 port engines? cars.cars.cars Nitro On-Road 55 11-16-2005 10:51 PM
.12 3 port Engines for Sale Riketsu R/C Items: For Sale/Trade 4 07-14-2005 05:37 PM
New .12 3 port turbo Engines on Ebay poop R/C Items: For Sale/Trade 0 04-29-2005 06:14 PM
Kawahara Zac Modified OS 5 port Engines alana07 Onroad Nitro Engine Zone 1 02-18-2004 03:41 PM
SEO by vBSEO 3.5.0
