1/8 SET UP HELP
1/8 SET UP HELP
I have a race tonight and I am having trouble with on the throttle steering. I would like some input on how to help this problem. I have a Jammin. There are just massive amounts of understeer while I am on the throttle.
Or try to stiffen springs or replace with thicker shock oil on the rear to minimize transfer of weight to the rear when you throttle to decrease rear traction.
Is it the RTR version? What diff oils are in the car?
the diff oils are what comes stock on the rtr
Not sure what the rtr comes with could be just grease. Try putting 5k-7k-2k or 5-5-1 if the track is very rough and loose. hope this helps.
Wow.........
Toe out in the front will absolutely decrease on power steering. It will increase off power steering entering a turn.
Rear toe will keep the rear end under the car. If you have too much it will make the car push on power. This is a rotation issue and used to hold the car under control. I like running as little as I can to make it the most efficient.
Not sure about the diff oils on this car. I would look at the Jammin post to be sure. Trying 5-5-2 would not hurt.
Increase your front castor.
Increase your front kick up.
Decrease your front toe out. Make it more straight.
Soften the rear of the car.
Decrease your front track width.
Stiffen your front sway bar.
Hope this helps.
TEX
Hope this helps.
TEX
