Old 08-01-2006, 11:54 AM   #1
Default Clutch Bell Bearings...help
Ok I've had luck with assorted bearings here and there, but a past race this past weekend at RC Pro Michigan series ended with me in second but both bearings are locked solid, thank the racing gods I finished the full race!
Can I get some opinions on good bearings to use? Brands? Sealed, unsealed?
binaryterror is offline   Reply With Quote
Old 08-01-2006, 12:42 PM   #2
Avid bearings. $1 each. Get the Revolutions. Face rubber shield out. Blow out w/ 100 psi air, wipe off grease. Run for 1 gallon. Throw away. Repeat.
M.Cartwright is offline   Reply With Quote
Old 08-01-2006, 12:57 PM   #3
rmargiotta's Avatar
Trader Rating: 51 (100%+)
Send a message via AIM to rmargiotta
I second that. Those are the only clutch bearings that I haven't had blow out, I just replace mine after a little over a gallon as stated above using the same technique.
Love these things!
- Cold Hard-Earned Cash Money -
rmargiotta is offline   Reply With Quote
Old 08-01-2006, 01:14 PM   #4
Crim3Wav3's Avatar
If you shim the bell properly (thanks mretmr) you will notice your bearings lasting quite a while.
That being said, even with proper gear mesh and bell shimming, the BOCA bearings last only about 1/2 gallon before they literally explode in your bell.....
The best bearings I have come accross were metal gold seal 5x10's from the old Kyosho Ultima...they were sold in a bubble-pack with a bunch of other bearings....they lasted well over a gallon when i found them in an old pit-box i had stored.
Crim3Wav3 is offline   Reply With Quote
Old 08-01-2006, 07:29 PM   #5
KK-racing's Avatar
Are you referring to the BOCA's ceramic bearing ? It cost hell of alot more than rubber-sealed/metal-shield type.
Got some of those metal-shield type from hardware store previously & was surprised to notice 'Kyosho' printed on the shield. More surprises is they do last much longer.
Do 'IT', with a DUREX (safely) !!!
KK-racing is offline   Reply With Quote
Old 08-01-2006, 09:39 PM   #6
SpeedBump57's Avatar
Shimming your clutch bell properly and setting you gear mesh are the two best things you can do to prolong the life of your bearing. When shimming the bell you need to have between .35mm to .45mm of end play. Anything more or less and you are asking for trouble. Its hard to explain how to set gear mesh in writing just make sure it is not too tight and that the engine is as close as possible to being 90* to the spur gear as you can get. Also as stated above with the Avid bearings at a buck a piece you cant go wrong.
SpeedBump57 is offline   Reply With Quote
Old 08-02-2006, 07:55 AM   #7
Thor23's Avatar
Amain hobbies has the clutch bell speed bearings for a buck a bearing....
Personally i replace mine every race day even if the bearings still feel smooth....
Thor23 is offline   Reply With Quote
Old 08-02-2006, 08:33 AM   #8
Thor that is a good idea as well but after a while you will learn to know about how much longer you can run the bearing just by look & feel. Having said that if there is any dout going into a main I replace them.
Old 08-02-2006, 11:04 PM   #9
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
the bearings i get are $4 each!......they last for AAAAGGGGGGEEESSS....my 1st rubber sheilded bearings for my savage on the stock clutchbell pretty much got heat treated from the heat of the clutchbell and the rubber shield literely melted the rubber and only had the little ring there lol and the bearing had turned that sick ass looking blue......they still run but i replaced em for a new set of metal sheilded...and havnt replaced em for the past 8 months...still run like new but i dont realy run in dirt asmuch....
FG leopard comp w/Trevor Simpson 28.5 bzm crank
HIP Baja 5sct
AE tc5 3.5t speed monster,Futaba 4pks
Raptor G4 ,Raptor e550,Gaui x5,Mini titan v2,Precision aerobatics bandit 4s monster,Carbon z scimitar Jr 11x
ProudSavageOwnr is offline   Reply With Quote
Clutch bell bearings (failure) slumlord Nitro Off-Road 17 09-10-2008 02:41 PM
ofna clutch bell bearings for the hyper 7 pro/pbs? xxx-ntad2 racer Electric Off-Road 5 03-29-2007 03:40 AM
looking for ceramic Clutch bell bearings jeffrock Electric Off-Road 2 05-30-2004 11:59 PM
WANTED:Savage parts-clutch bell, clutch shoes, rear driveshaft,etc..Orlando, Fl. 10gter Florida Racing 0 01-26-2004 08:54 AM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 04:01 PM
SEO by vBSEO 3.5.0
