Old 07-17-2006, 05:12 PM   #1
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Default About Charging and Discharging rates ...
Hi guys,
Just bought an ICE Charger from Duratrax and i need some knowledge about charging and discharging rates, the batteries i usually use are :
- Transmitter = 8 x 2.500mah Sony Batts (NiMh)
- Receivers = 1 x 1.200mah and 1 x 1.400 mah batts (NiMh)
- Starter Box = 2 x 3.000mah and 2 x 3.300 batts (NiMh)
- Glow Plug Heater = 1 x 5.000mah (NiCad)
I would like to know about normal charging rates and "fast-on-track" ones ...
Thanks !!!
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 07-17-2006, 05:41 PM   #2
Scottmisfits's Avatar
Your receiver packs, transmitter pack, and glow ignitor can be charged at 1 amp. The starter box batteries will be fine with a 5 amp charge.
For the receiver packs, transmitter pack, and glow ignitor pack, you don't need alot of power out of them. Charge them through the week lower than 1 amp. Maybe 0.5 amp or lower even. I discharge my receiver packs once a month at about an amp and then charge them at 0.1amp. When I'm at the track I charge at 0.5.
If it's something you need alot of power from, charge it at a higher rate (no more than 1.5 amps for smaller batteries). If you need something to last, charge it at a lower amp rate.
Scottmisfits is offline   Reply With Quote
Old 07-17-2006, 05:57 PM   #3
All that you listed should be charged at 1.0 or lower. I usually charge my tx pack at .5, . or .7, or when I use step charging I go .7 .6 .4 so it gets a nice full charge. The only time you need to charge at over 1.5 is for racing packs.
gatermaxx is offline   Reply With Quote
Old 07-17-2006, 06:17 PM   #4
Bit_Rusty's Avatar
Smaller nimh's should be charged at 1A.
The 6 cell stick packs for your starter box can be charged at whatver you can throw at it. For ease's sake, 3000mah will take about 1hr @ 3A, the 3300mah will take about 1hr @ 3.3A.
Seeing as you're not relying on any of these batts to propel your vehicle, no need to be fussy about discharging/equalisation techniques.
Every now and then (once per month... when the weather's bad) juscharge them to 0.9v per cell...
So... transmitter pack - 7.2v... starter box packs - 5.4v.. receiver pack (5cell) 4.5v.
The glow igniter is a nicd - so best to discharge this to 0.9v before every charge.
Lol - a lot of battery charging for a nitro powered vehicle, hey?
Bit_Rusty is offline   Reply With Quote
charging rates rjs_13203 Rookie Zone 18 07-17-2008 01:36 PM
Can someone explain charging rates? EllTG Electric On-Road 3 01-06-2008 02:16 AM
Charging and Discharging inet-projects Rookie Zone 3 12-10-2005 07:27 AM
charging rates for 3300s John_S Electric On-Road 8 08-03-2004 01:36 PM
Battery Charging Rates yendor Singapore R/C Racers 9 02-29-2004 07:52 PM
SEO by vBSEO 3.5.0
