Old 06-30-2006, 06:51 AM   #1
Default piston direction traxxas 2.5
OK dont mean to sound stupid but does anyone know which direction the notch in the piston skirt shoulf face...toward the clutch bell side or the exhaust side....thanks
reefkeeper is offline   Reply With Quote
Old 06-30-2006, 07:45 AM   #2
SpeedBump57's Avatar
I am not 100% in your case but the notch most always faces the clutch bell side. This is to make room for it to clear the crank. As well the back plate usually has a cut in it to make room for the piston.
Just as a tip make sure you have the piston at TDC before you put the backplate back on or you might crack the piston.
SpeedBump57 is offline   Reply With Quote
Old 06-30-2006, 05:34 PM   #3
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
the cutout in the piston is suppose to be lined up with the boost port.,,(the 2nd biggest port,not the exhaust port)
FG leopard comp w/Trevor Simpson 28.5 bzm crank
HIP Baja 5sct
AE tc5 3.5t speed monster,Futaba 4pks
Raptor G4 ,Raptor e550,Gaui x5,Mini titan v2,Precision aerobatics bandit 4s monster,Carbon z scimitar Jr 11x
ProudSavageOwnr is offline   Reply With Quote
Old 07-02-2006, 09:55 AM   #4
Registered User
On the TRX 2.5 the piston can only go two ways, with the notch in the piston skirt to the front of the engine (clutch bell) or rear (exhaust) it goes toward the exhaust.
Check out the traxxas site for the PDF exploded view of the engine, it will give you a detailed set of instructions on how to service the engine and put it back together properly.
Desolas is offline   Reply With Quote
Traxxas Piston/Sleeve and Connecting Rod lincpimp R/C Items: For Sale/Trade 6 08-03-2008 04:09 PM
WTB 4SETS NEW PISTON/SLEEVE for TRAXXAS 3.3 wguapo R/C Items: Wanted to Buy 0 01-06-2008 08:30 PM
WTB 4SETS NEW PISTON/SLEEVE for TRAXXAS 3.3 wguapo R/C Items: Wanted to Buy 0 01-04-2008 05:22 PM
Traxxas 2.5 motor piston and sleeve Revoguy R/C Items: For Sale/Trade 2 05-02-2007 08:38 PM
Which Direction is the "normal" direction bvoltz Rookie Zone 8 07-26-2005 12:08 PM
SEO by vBSEO 3.5.0
