Old 06-26-2006, 08:18 AM   #1
Send a message via AIM to oMONSTERo Send a message via Yahoo to oMONSTERo
Default Help Identifying cells?
This is basically for practice, but maybe I get a "usable" pack. These batteries were collected from here and there, so I really have no history for them. All I know is I had one that had obviously been converted to side by side, since it had no label (therefore, no idea what MAH is), and another thats a Dynamite 1500 stick pack that didnt work very well. Heres the bad part. I cut them both open and the cells inadvertantly got mixed together. Is there any way to distinguish what mah a cell is? I have a Super Brain 969 to check them out with. If I can determine which cells are which or if they are the same, maybe I can get ONE usable (side by side pack - YAY!) pack from the two "bad" packs.
Like I said this is mainly for practice, but I dont know what might/could happen by mixing MAH values.
Thanks in advance
oMONSTERo is offline   Reply With Quote
Old 07-01-2006, 03:38 AM   #2
MadRacer's Avatar
Trader Rating: 31 (100%+)
The only way is to number the cells 1 to 12 than charge them one at a time at the same amps than discharge them at 10 or more amps and record all readings mah in and mah out, time and resistance.
The old ni cads would have a higer resistance and not as much voltage. Match the cells to be as close as possable than put the pack together.. A lot of trouble for a pratice pack. I have done this when a good pack has dropped a cell, you all so need a good charger.
Boondal vintage Tamiya's
QLD State Titles winner in 6S EB CAT
MadRacer is offline   Reply With Quote
Need help identifying a chassis!! vrcoupe Electric On-Road 5 12-13-2007 04:15 AM
Help identifying a car. DangerDave Rookie Zone 3 05-25-2007 08:58 PM
Need help identifying and armature PWA Electric On-Road 9 05-10-2007 11:08 PM
Need help identifying RC buggy eBayfreak Electric Off-Road 2 12-13-2005 02:22 PM
Need help identifying old Kyosho F1 RC car MJGunn Rookie Zone 0 01-11-2003 05:31 PM
SEO by vBSEO 3.5.0
