Old 06-04-2006, 04:33 AM   #1
Aceboy's Avatar
Default Engine Overheating - Change of wheel Size?
I recently changed my wheels from a 1:10 to a 1:8 - I'm running a Tamiya Nitro Thunder. Prior to changing the wheels my car seems fine but after i've changed it i notice my engine heats up very quickly after a short run, at one point there was a small puff of smoke too (luckily my engine is still alive!) - it went up to 90 degrees C.
My question is, is my problem caused by my gears? I havent changed my driven gear thus making the engine spin harder to push the larger wheels (since the wheels are now bigger). the hobby shop guy suggest i should change the driven gear so its better suited for the larger wheels, but didnt say it will over heat my engine.... ?!? whats your call guys. thanks for any advice
p.s new wheels are definetely worth it! heaps better steering but doesnt cover a smoked engine!
Aceboy is offline   Reply With Quote
Old 06-04-2006, 05:52 AM   #2
bigger tires will stress more than just your engine...
they stress your drivetrain, suspension, basically the entire car.....
yes you need to regear your car for the bigger tires.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 06-04-2006, 05:57 AM   #3
Aceboy's Avatar
will this damage my car permanently if i continue using it say for another tank or two.
Old 06-04-2006, 08:19 AM   #4
Trader Rating: 14 (100%+)
no damage is permanent, you can rebuild things, but it is not good to put on bigger tires unless you re-gear the car. I don't know if you can re-gear low enough to get the right ratio you need. If you are to continue to use bigger tires, go and get the smallest clutchbell and largest spur gear you can get for your car.
o.s. power is offline   Reply With Quote
Old 06-04-2006, 04:00 PM   #5
90 degrees Celsius? Isn't 100 degrees C = 212 degrees F.?
90* C isn't anything to worry about.
BobbyDoyle is offline   Reply With Quote
Old 06-05-2006, 01:02 AM   #6
WildChild's Avatar
Send a message via Yahoo to WildChild
actually most say that if you arent somewhere in that ballpark you are causing premature wear on your engine...
also is the better steering response due to the decreased throttle response due to overgearing or is it the higher ride height...
WildChild is offline   Reply With Quote
Old 06-05-2006, 08:32 PM   #7
Aceboy's Avatar
My wheels were worn out before i got these wheels, but regardless - the bigger wheels definetely gives me better steering - not sure if it has to do with the height (i havent lowered it). I will take it out for a spin in the tracks and see if it will flip, if it doesnt i will probably keep it that way.
in regards to the temperature, i concerned because i saw smoke coming out..... i not sure if this was caused by burning leaves (caught in the engine) but the smoke was obvious....
Change M11 Steering Wheel?? superx421 Radio and Electronics 3 05-27-2008 12:12 PM
Need help with engine overheating. rdsoxfn Nitro Off-Road 4 08-21-2007 06:09 PM
DOES MOTOR TEMP CHANGE WITH SPUR SIZE 16skyline Electric On-Road 6 04-28-2007 01:09 AM
Engine overheating! HELP!!!! Thedub88 Nitro On-Road 1 08-15-2006 06:05 PM
engine overheating? 92tsiawd84 Rookie Zone 5 08-14-2003 03:01 PM
SEO by vBSEO 3.5.0
