truck tires
having toruble taking truck tires off the rim i want to keep the rim if you have any easy ideas please share thanks
Pre heat you oven to 350 turn it off the place the tires on there for about 10 minits .
the tires should come right off. it works for me. its the easiest way |
If the rims are made of the same material as Losi's, you can soak them in acetone and the glue dissolves.
dunno they are hpi rims
Boil them for 15 minutes, let cool, pull em off.
I'm noticing a recurring theme of heat :) |
baking them or acetone, or both, I have had bad experiences with the boiling, makes the rubber to soft and tears easier. I have had to bake monster truck tires for up to about 25 minutes for complete removal. If you bake for 15, and then acetone for several days they will come out all clean and shiny, and you save the rims and the tires.
HTH Rod |
be careful with the acetone...if it gets dirty it will stain your rims...seen it when i was carpet racing...they kinda get to be almost a brown color...but the acetone works very well...
ive tryed acitone before and it didnt work how long do you leave it in there for?
