Old 05-14-2006, 04:06 AM   #1
Default Novak Brushless Problem
Has anyone had a problem with the motor going dead during a run or after a crash then coming back on line? I'm currently running the 6.5. I did not have this problem with the 5.5. Sometimes it comes back by it self and other times I have to turn the ESC off then back on.
LClarke is offline   Reply With Quote
Old 05-14-2006, 07:11 AM   #2
TonysScrews's Avatar
Sounds like it is thermaling. Have you monitored the temps on the motor or ESC? Perhaps it is over-geared or something binding in the driveline?
Tony P.
Tonys Screws LLC
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 05-14-2006, 07:58 AM   #3
It happenrd to me one weekend. I had a loose wire. I had spliced the motor wires and one had come loose. I could not see it. I had to tug on it to discover it. Good luck.
ddcarter3 is offline   Reply With Quote
Old 05-14-2006, 09:42 AM   #4
My buddy has this happen everyonce in a while, or after a big jump, it isn't like with the brushed motor s where they get stopped and you slap the bottom and roll them back and forth for a second, it actually goes offline. I know that somewhere I saw someone recommending using a capacitor with the end made into a connector plugged into the receiver, this keeps the voltage there for the receiver, especially if you are running spektrum.
gatermaxx is offline   Reply With Quote
Novak Brushless 13.5 problem beez Electric Off-Road 2 04-13-2008 06:37 PM
novak brushless motor problem ? stew215 Radio and Electronics 3 02-17-2008 09:12 AM
Novak Brushless problem shooter26 Electric On-Road 8 09-24-2007 02:27 PM
Novak Brushless Problem revzalot Electric On-Road 9 09-01-2004 08:01 AM
Problem with Novak SS Brushless System DraKhen99 Electric On-Road 3 07-24-2003 07:05 PM
SEO by vBSEO 3.5.0
