Priming
Priming
Hey
I have a Duratrax Nitro Evader BX and im having some problems
It wont prime, i put my finger on the exhaust and pull with everything turned off and i see none or sometimes a little bit of gas come up the line and it never goes any farther. i have checked the lien to my pipe and its find. All of the gas that should be goign to my motor is coming out the pipe all over my fingers and my rag when i prime it. Any ideas?
by the way
Is there suppost to be a gasket inbetween the motor and the pipe?
thanks
-Ross-
by the way
thanks
-Ross-
hmm
take the line of the carb and blow into the exhaust line see if fuel flows freely
then check the carb with another peice of fuel line. blow into the line on the carb and listen for air .
has it been sitting for a long time
maybe old fuel is blocking the fuel inlet on the carb ..
that did it
i put a bike pump through the gas line and this tiem i plugged the line that goes to the exhaust instead of the end and it primed up with about 4 pulls
thanks
thanks
