Old 04-29-2006, 09:50 PM   #1
Default help
i have a kyosho inferno 1/8 scale buggy i am having trouble with jumps when i go over a jump my buggy allways lands on its nose and allways rolles is there eny one than can give me some tips to stop that happening i have 60 grade silicon oil with standard shocks thanks
bulldog79 is offline   Reply With Quote
Old 04-29-2006, 10:21 PM   #2
xlgraphicspro's Avatar
try putting a combination like 50 weight in the front shocks and 40 in the rear, or step down and try 40 up front and 30 in the rear.
also you could try to change the diff oil, if it's too thin in the front or rear, it could cause a loose feeling when your on the gas!
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 05-01-2006, 12:21 AM   #3
gacjr0's Avatar
Trader Rating: 15 (100%+)
Watch what your doing with the throttle before-during-and after the jump your thottle/brake inputs will have a huge inpact on the attitude (nose up/down) of the buggy. In the air if your buggy is nose down, goose the throttle to bring it up. If its flying nose up, tap the brake to bring it down.
You'll also need to experiment with the approach to the jump, usually your throttle will be between full punch or 1/2 it just depends on the jump/car/conditions etc.
-Dangerous with power tools-
gacjr0 is offline   Reply With Quote
SEO by vBSEO 3.5.0
