2wd buggy - cornering spinning out
#16
My buggy always feels slidy on fuzzbites especially after 2-3 races. Simply put my car is not set up for fuzzbites. A spikier tire liked nessi or siren helped a lot tame the rear end. Only had some slight problems with slow cornering catching too much. More speed helps rotate the rear.
#17
I'd start with rebuilding your shocks and diff. Over time they leak or the the oil breaks down. The oil goes in clear and as it gets dirty it doesn't work the same. Or the diff will just leak it out and some times the shocks do as well.
Freshen those up, and make sure all the suspension moves freely with the shocks off.
#19
It can be shocks, roll bars, droop, kick-up or a combination. Is the rear coming up from braking, from roll, or both?
Some things you can try:
- Reduce front kick-up so the car dives less off power and under braking. When the car dives the rear comes up and loses traction.
- Increase rear droop so the rear can stay in contact when it dives and rolls. Droop is often overlooked, losing the rear on corner entry can be a sign of too little droop.
- If it's happening from roll, add a thicker roll bar to the front or a thinner on the rear. If the front rolls more than the rear can handle the rear inside will come up. Increased rear droop can help this too.
- Increase front spring rate so the front rolls less keeping the rear down. Don't do this just for cornering.
- Increase front dampening so it rolls slower, which may only delay the spin, or might give you just enough time to avoid it. Don't do this just for cornering either.
#20
This goes along the lines of a rebuild, but one really annoying thing that you can check is to see if the diff outdrives are notched from the dogbone pins. If they are, and I have seen it several times on AEs, it will tend to lock up the suspension when you get on power which can do all sorts of nasty things. Just saw this on my buddies SCT.
#21
R/C Tech Elite Member
Note to OP, make sure you only change one thing at a time.
#22
Wouldn't more rear droop cause more weight to shift to the front end thus causing the rear to come around due to the loss of traction? A guy at my track was having the same problem, it came down to him having a ton of rear droop causing too much weight transfer to the front which caused the rear end to break loose entering corners.
In Invisible Speed JQ basically advises starting with too much droop and reducing it until you stop getting faster. So I start by making sure more droop won't improve things.
Thank you for pointing it out it deserves explanation.
#23
So thanks again to everyone and especially Kufman for the advice
#24
Thanks for all the replies on this thread guys! I think Mr Kufman here provided the advice that I was looking for! I tore this car apart from the ground up and didn't see anything too crazy or out of the ordinary. However, the outdrives were pretty pitted from the driveshaft pins. I rebuilt the diff with new outdrives and the car seems much more drivable now! It was honestly pretty shocking how big of an impact pitted outdrives made on the car.
#25
Thats why its best to post a couple pics. Hard to guess everything over the internet. But a local got you sorted out, which is great.
#26
#27
Properly tuning the diff makes a MASSIVE difference in how the car handles. You can change your shocks a dozen times, and the car will never feel right. Rebuild your diff, set it right, and magically, the car starts to perform as intended. Its crazy how much of the cars turning and overall traction is solely because of the differential functioning properly.
#28
Super Moderator
Thanks for the follow up!
I used to laugh at tools like this but when it comes to rebuilding your ride and you liked how your car worked before, this type of tool is very helpful.
