XXX-CR Thread
#5761
Was in my LHS on Wedsneday since i have a xxx bk1, cr mix gooin on. and a xxxt. THe 22 slipper plates on the package said 22 and all xxx. (so im hoping it will work on my jrx and xx platforms also. ) but i also heard some 22 drivers before were also running B4 slippers at some points.
#5762
Is the graphite front arms still available anywhere?
#5763
I don't know about new but you can still find the J-concepts bodies for the XXX buggies, which I think are the best looking buggy bodies ever made for any car.
I have several sets. I'll sell them to you for $125, including a very nice XXX-cr roller and several sets of tires.
#5765
Grabbed a XXX yesterday. Very surprised with the handling and parts quality. Performance wise it's better than an old Team C TC02 I had, feels the same except the XXX has more traction out of corners, and as good as my B4 but again with more rear grip. Really like how the steering feels.
Compared to my TLR 22 with 2.0 geometry and shock seals... The 22 feels numb and stable. Once I get rid of the slider the scale will tip for the 22 surely.
#5766
I had a XXX-CR lying around that I got from a friend that I decided to rebuild. Just waiting on a transmission case and diff balls to rebuild the diff. I probably put more into it than I should have but live and learn. I'll post up some pics once I reach my post count.
#5768
#5770
Just not sure what electronice or motor I will run in it.
After reading this thread I may want to pull apart the gear box just to take a look. Guess I should tear down everything if I want to do it right...
Still not sure what I want to do with it... I may just run it wound the track for ole time sake.
#5771
#5772
I have the XXX-BK, got it when I was much younger. Just dusted it off and have been using it but of course it needs some resto work to get it back to brand new condition. Any Are the parts for the CR / BK / BK2 pretty much all interchangeable ? what is the actual difference of the BK and the CR?
#5773
the XXX-BK (if it is a verison 1 with black tranny case) was basically my favorite version of the car from the line up. I put the VLA arms, spindles, and hubs from the BK2 on that was basically the car I ran at the end of the XXX life. So there were arm and pivot changes and a tranny change in the middle of it all.
#5775
