Old 04-17-2006, 01:31 AM   #1
Default Pressure line
Does it matter if the pressure line on your pipe is before the weld? ( closer to the header ) or after?
Im trying to figure out if this could be my tuning problem.
PSiDAWD is offline   Reply With Quote
Old 04-17-2006, 05:25 AM   #2
brad996's Avatar
I would think that somewhere around the middle of the pipe or out to the end what is the motor doing wrong and I may be able to help more I really dont think the problem is with the pressure line I have never seen that before it could be with the header being to short or to long I have had that problem and it took me forever to get it right
TLR 22 3.0, TLR 22-4, TLR 22T 2.0 8ight 4.0
brad996 is offline   Reply With Quote
Old 04-17-2006, 07:15 AM   #3
xlgraphicspro's Avatar
do you have the kind of pipe where you just stick the tube into a hole in the pipe like on an rc 10 gt stock pipe, or a drake pipe?
If so, you have to cut the end of the tube at an angle and stick it in the pipe open end facing toward the front of the pipe.
That way you don't get any exhauste "blow by" going into your gas tank.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 04-17-2006, 09:06 AM   #4
the pipe didnt come with any holes for the pressure line. so i drilled on right ontop just after the weld, closer to the stinger. and just stuck the pressure line on it.
should i plug that and drill somewhere else?
Old 04-17-2006, 10:43 AM   #5
Ducati-Rider's Avatar
Default Location
I belive you want the pressure take off near the fattest part of the pipe, as to lessen the exhaust pulses from the reciprocating piston.
If you locate it near the header - you will be dealing with variations in throttle output, so that the low end and high end pressures will be so different as to cause tuning problems.
Locating it in the fatter part of the pipe, lessens the pressure variations
and stabilizes the pressure flow.
Ducati-Rider is offline   Reply With Quote
pressure line question Baedarlboo Nitro On-Road 18 03-20-2008 01:43 PM
pressure line karimbs Onroad Nitro Engine Zone 3 01-03-2007 01:24 AM
pressure line |jan Rookie Zone 12 02-10-2006 08:13 PM
where should the pressure line go? smidge Nitro On-Road 1 12-26-2004 07:30 AM
Pressure Line.... [HPI]RS4SS Nitro On-Road 23 12-30-2002 05:57 PM
SEO by vBSEO 3.5.0
