Old 04-12-2006, 05:02 PM   #1
LSUsportsfreak's Avatar
Default Installing OS 21 RG in Ultra MBX Comp??
I purchased an OS21 RG today from my LHS. Upon reading the Ofna blowup of the buggy.... it says something about a "spacer" that needs to be used for OS engines. Anyone installed one of these motors in their Ofna, and have any tips?
Non-Pull Start Engines...
Alum. Washer behind the flywheel is not needed when using Force engines or similar types. O.S. Engines will
require washer spacer.
To check!..place the brass corn against the engine bearing, then flywheel. You should be covering one or two
thread of the engine shaft. If this is the case, you do not need an additional washer behind the flywheel.
You must cut the engine shaft if too long. Count 6 threads in front of the flywheel and mark. This is all you need to
tighten the clutch nut and mount the flywheel.
Force Pull Start Engine w/threaded shalf...
Force Pull Start Engines required NO spacer and no shaft cutting. The engines comes with an alum cast driver
washer, you use this part as the spacer, not the alum. washer shown. Also, use the special flywheel brass corn.
This corn fits the thread shaft diameter so you can tighten the flywheel against the drive hub.
LSUsportsfreak is offline   Reply With Quote
Ofna 1/8 Ultra MBX Comp - $250!! OBO JGruber R/C Items: For Sale/Trade 11 05-23-2008 05:37 PM
ofna ultra mbx comp jatoman1992 R/C Items: Wanted to Buy 8 09-24-2007 04:35 PM
F/T or F/S ultra lx comp savagebasher25 R/C Items: For Sale/Trade 2 10-23-2006 11:55 AM
OFNA ULTRA MBX COMP Hicksey Electric Off-Road 1 01-31-2006 02:55 PM
Couple of questions on the Ofna Ultra LX Comp and the MBX Comp knucklebusta Electric Off-Road 2 10-10-2005 08:36 PM
SEO by vBSEO 3.5.0
