Losi 8ight Pics
#691
I skimmed over the manual today. Looks ok. I did notice they goofed the picture of the body clips (they shoe an 'e' clip instead). From what I understand the alum chassis braces are not standard.
#692
E-clips are just used as a symbol
but not 1 word about the internals of the tank or installation of the filter in there !!! that's a blank
no inserts in the suspension supports
but a plain alu plate and plastic cover to guide and stop the axles...
is it possible to tune the rear toe-in in fact ? no outboard toe-in neither ?
center diff supports in 1 piece ?
#693
#694
some pics for you guys waiting for this machine...
#695
That must be Ron or Gil's car from the nats. Isn't that is an OS TZ18 small block engine?
#697
UPDATE!
Losi 8ight Off-Road 1/8th buggy screw kits are now in stock!
Losi 8ight 278-piece high grade 8 alloy steel socket head screw kit. Kit includes all applicable cap, flat and button head screws, as well as nuts, washers, lock washers and set screws. This kit is a stock replacement kit that comes with all the Standard SAE screws. We will have a metric conversion kit shortly.
Kits will begin shipping Tuesday, September 12th, 2006.
Thanks and best regards,
#699
Originally Posted by adam lancia
tony, i like the idea of the metric conversion kit. any idea why losi would go with standard-size hardware when the rest use metric? only reason i ask is if there could be an advantage to one type or another in specific areas of the car...thanks!
#700
Originally Posted by o.s. power
it looks like an .18tz, but can you fit a Jp-1 pipe/manifold onto a motor that small? I would think that the manifold opening is too large for the motor.
#701
What kind of screws does the 8 come with? ....it's not phillip heads is it
#703
Then why the screw kit.... unless it's stainless?
#704
It is an OS .18TZ. I'm running a TNT Modded TZ in my Mayhem Pro buggy. It's easy. You just have to drill and tap the motor mounts to fit the TZ holes. 1.1 springs, aluminum shoes and a 13t bell. I'm also running the SH U header and Torque pipe. It runs fine.
#705
