t3
t3
hi i need some help on gearing my t3 ... i have a new 19 turn trinty motor... what pion do i need ? thanks for the info..
Suspended
we need more info. what motor is it are you racing or bashing. what spur do you have. once i know that i can tell you
i have the chamelean 2 motor ... and i thank the spur gear is a 87 ... and i race ....
Suspended
i would sugges starting at an 18. the chamelion like to be geared up in my opinion. i ran between a 18 and 22 on my truck with that motor. it keeps getting faster and doesnt really get much hotter.i would only suggest 20 or higher if you have a lathe and can cut your motor and rebrush after 3 runs because it will burn the brushes pretty bad
I have a p2k pro,and im geared 20/87...but i think i need new brushes...where can i get them at? also i have chamelion 1 and it too needs brushes.../\
ok so a 17 pion wont be to big.. thanks for all the help...
well, got my b3 diff installed this morning...got this left to do:
get new wheels and tires installed
find a esc for it!
find a esc for it!
Tech Legend
Your LHS should be able to sell you new brushes for your P2k2 motor.
I would go with Reedy 767s or if you can't get those Trinity 4499s . I usually drilled a hole about 1/3 deep in mine to make the most power using a #42 bit.
You will however need to cut the comm before installing new brushes. If you don't you might as well just take the money you spent on the brushes light it as it will do that much good on your motor.
Another brush that is good on the torque side of things but doesn't make overall power is the Reedy 766 . brush also lasts longer than the 767.
Finally, if you want a brush that lasts a REAL long time, the trinity XXX brushes do. not sure on the power output from them, but, based on what the Late Big Jim said about them in 19 turn, they were THE brush to use if I recall correctly.
i got to get a esc for my t3... cant wait to try it out this summer
upgrades to the t3
RPM:
front bumper
gear cover
ball ends
spring holers
rear blocks(not used)
RPM:
front bumper
gear cover
ball ends
spring holers
what esc should i get?
duratrax,tekin,LRP,or novak are all good brands to get...
any of you"s want to trade a esc ? i have some extra rims for a t3 and tires .. dont matter what esc .. .. i really need a esc ... lol
nice truck... i need to get a esc and a body....
