How do I charge my Lectron Pro #3S5200-505 11.1V 5200mAh 50c 2c charge rate lipo?
How? I can’t find any YouTube videos I’m very confused and need to know what AMP to charge the battery I listed on the title.
my charger is the onyx 245 charger and I used it a while ago but don’t remember how to use it and I can’t find the information I need on the manual. And Simone said “if your charging a 3s lipo you can only charge it up to (3.33 amps)”
the number of cells don't determine the charge rate. The "C" rating gives that distinction. You could theoretically charge at 30C but it would destroy the battery in a short amount of cycles. The 3S means you need to charge it up for nearly 12 volts. Charge your battery at 8 amps @ 4.15 volts per cell and you'll be fine. Google your charger and find the manual that way.
mah X .10 give you charge rate for 1 c charge if ur going to a 2c charge then X2 it. 5.2 amps for 1 c and 10.4 or even 10.5 for 2 c. 5 amps is max on that charger.. good luck(no i dont like the onyx brand charger)
