New Sportwerks Turmoil ARR Buggy (race legal) >
Old 06-14-2006, 01:08 PM
  #31
Trader Rating: 58 (100%+)
Thanks kinda what I thought, but it seemed like overkill judging from the small amount of pressure coming through there.
Has anybody had trouble getting fuel? I have a hard time priming & seems I get a lot of air.
Thanks for the reply.
Bigcheese is offline
Old 06-14-2006, 01:21 PM
  #32
SpeedBump57's Avatar
It also helps prevent a lean bog condition after a pitstop.
SpeedBump57 is offline
Old 06-14-2006, 06:03 PM
  #33
From Sonny Brown at Horizon..
It's to prevent lean bog after re-fueling.
Old 06-14-2006, 08:36 PM
  #34
Thanks its back on. I did the ackerman mod tonight for my mayhen pro. I also changed to arms back on caster. Had a push under power.
Old 06-16-2006, 10:59 AM
  #35
I drove this new car over the weekend, and must say....im sold. Car handled unbelievably the only thing more surprising is how cheap the car is. Alot of the local guys at my track put it down because it gets an "economy" level tag, but I like it, and will be likely picking one up.
runnin rc10 is offline
Old 06-22-2006, 06:16 AM
  #36
Default Results
Turmoil got a top 5 finish at the Panther race.
brian kadow is offline
Old 06-22-2006, 04:52 PM
  #37
That Turmoil had a little help! How about some props to the young gun driver!
Old 07-01-2006, 03:44 PM
  #38
Troy_Konitzer's Avatar
Location: Abrams, WI (Yes the same town as CJ & John Greaves)
How are the new Turmoil's holding up?
Troy
Troy_Konitzer is offline
Old 07-01-2006, 07:20 PM
  #39
Turmoils take 1st and 2nd about 8in. apart at Glitchers RC Firecracker cash race.
The Sportwerks Prototype Arena Truck also took the win in the UMT class.
So far we have had no issues at all with the Turmoils.
Troy Weatherholt
gasser is offline
Old 07-01-2006, 09:12 PM
  #40
Old 07-01-2006, 09:14 PM
  #41
Troy good to see you and Derek again, congrats to you both. Glitchers was a good time. To bad the turnout was a little off. I did walk away with a 4th place finish and some fuel. Thanks for the juice! Me and Doug had a fun time for the last 10min, what was his last name as I don't think I have met him before.
See ya at round 2
Old 07-02-2006, 09:57 AM
  #42
Doug Richter, He has been running pretty well at Hardesty's so far this summer. It was great to get to race with you again. Too bad we are soo far apart to get to race more often.
gasser is offline
Old 07-02-2006, 10:43 AM
  #43
Old 07-03-2006, 01:23 PM
  #44
RCGaryK's Avatar
Troy, could you please post Derek's setup from Glitchers? I'm trying to get some more low-speed steering out of the car while trying to plant the rear on-power. I'm in the middle of rebuilding the car just to clean it, so the timing would be perfect. Thanks.
RCGaryK is offline
Old 07-03-2006, 05:42 PM
  #45
Here is the set-up on Derek's car.
front shocks 45 wt Losi and grey springs
outer hole on the arm and middle hole on the upper row on the tower
Maximum caster
2 deg. camber
2 deg. toe out
center hole on the ackerman bar
Stock 2.2mm (black) sway bar
bones level
rear 35 wt Losi with Xray white springs (just a bit softer than the SW reds)
outer hole on the arm and middle hole on the lower row on the tower
0 rear anti-squat
3 deg rear toe
2 deg. camber
soft 2.5mm (Gold) sway bar
bones level
5,5,3 in the diffs
gasser is offline
