Schumacher stadium truck
#31
#33
the track is under construction.
#35
lol, i own it.
#36
Also, the wheels are same as AE wheels.
#37
#38
dremel with a sanding drum, i have this crawler link with an m3 headless screw it to put the post on.
Then you can easely rotate the post against the drum to make a nice dome.
#39
Build review. Sorry for the horrible paintjob!
#40
Razor, how does it compare to the 22t 4.0, or the ae t6.1?
#42
#44
#45
Almost finished my Storm ST build, it's been a long time since I built a Schue off road car and I'm well impressed with the quality so far.
Only issue I had was 2 of the screws for securing the pistons to the shock shafts were missing, so need to wait a couple of days until I can run it.
I've got the front and rear spring kits, and the anti-rollbar sets as well, so I should be go to go for tinkering with the setup. I also have the brass radio plate.
Are any other upgrades worth it on this car? A few people have recommended the new rear hubs from the L1R but I notice there's plenty of other alloy bits (including the alloy case for the gear diff) available so I was wondering if there's anything else I should pickup at the same time as I order the hubs.
Lastly - I normally race mod buggy, and run a 5.5/6.5 in 4WD and a 6.5/7.5 in 2WD. I've never run a stadium truck before - what kind of motor/pinion are people running on large grippy tracks in modified class?
