Can I salvage the Novak Havoc Pro SC ESC and motor?
I've dusted off an old OFNA Jammin' SCRT10 with super lower hour on it. When I got it I purchased the Havoc Pro SC ESC combo with the non-Ballistic motor option. It's a sensored, brushless setup, as many of you know. However, the truck will only run for several minutes before everything cuts out. I know the battery and radio are good because I tested them on another truck. I've tried resetting the ESC, checked temps, etc. I've read threads that mentioned a firmware upgrade but since Novak is no more that could be tough. I just replaced another Novak ESC and motor combo because the ESC was not compatible with non-sensored motors.
I'd love some advice on troubleshooting and hopefully salvaging this motor if the issue turns out to be the ESC. The motor has about an hour of run time on it and I'd hate to chuck it. Thanks in advance for your feedback.
I still run my novak ballistics esc and 4.5. Replaced my bearings. Just got back into the hobby. It sat on the self for since 2013. I did not do any updates since I picked it up. So I would say dont worry about the updates at all. I have 2 Novak system a 17.5 540 and the 4.5 540 system both work just fine. Without updates.
I use to race Novak and I went through 6 different Havoc Pro SC ESC (only bought 2) and I had all of them end up in a fire, The most recent just last year in a TLR SCTE 2.0. I had one that would run for about a couple minutes and it would start to cut out. I never heard anything about a firm ware update but after a few emails and calls to Novak tech support I would have to send it in and get a replacement. I tried different motors, wires, and sensor cables nothing worked. The coolest failure was my 2wd SC I went over a big double jump the Havoc ESC went up in flames mid jump truck looked like it something out of nitro circus. I never had much luck with that ESC many warranty claims. Switched brands and no problems ever again. So good luck
