Like Tree38Likes
Xray XT4 Thread
Old 06-10-2019, 11:44 AM
  #31
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
buddy of mine has one, hope to see it soon. He got it built and all ready for some turf battles!
Cain is offline
Old 06-11-2019, 10:33 AM
  #32
Trader Rating: 166 (100%+)
Originally Posted by moto44
Anybody know what wheels work on it? I know on my XT2 associated stadium truck wheels worked on it. I would think it would be the same for the XT4.
AE offset.
jpcopeland1 is offline
Old 06-12-2019, 02:19 PM
  #33
Tech Legend
Cain's Avatar
Got it give it a look see. didn't see it go though as my buddy ended up breaking a rear a-arm I think on an odd hit. It looks good though, got the standard XRay look to it. Body may take a bit growing used to here but looking forward to seeing him lay some laps down with it.
Cain is offline
Old 06-19-2019, 03:57 PM
  #34
I will have my xt4 built tomorrow to race (setup) on Friday. Gonna run it on carpet so I’m going to ditch the center diff for a slipper setup. Should be fun to test and tune. I have a ton of spare xb4 and xt2 parts so I only really need towers. Everything else is either xb4 or xt2 direct compatible.
Cain and aspiringracer like this.
Old 06-21-2019, 12:37 PM
  #35
For everyone that has built one of these, what kind of servo did you go with? Would a Savox 1258 be ok in one of these, for example?
Darkstorm05 is offline
Old 06-22-2019, 12:16 PM
  #36
If 1258TG then it will be fine. I would cringe at titanium gears though. But it will work fine.
Old 06-22-2019, 12:24 PM
  #37
First day out for practice and tuning on carpet went really well. I swapped my slipper out of my xb4 for the gear diff, which I will try again once I get the correct fluid,(going to try 500K to start). it steers really well, jumps amazing, and has corner speed to spare. Only change from stock was the change back pills to get 1 degree antisquat, and 3 degrees toe. two felt a tad bit wishy washy in the rear, felt the same on my XT2, and inner hole on rear arm. Everything else was box, so 97% is stock, It just seems to drive better then the tekno I swapped mid pack with with a friend of mine who has the ET410 fully upgraded and tuned specifically for carpet, which makes the trucks equal in price, but his still broke during the day, and mine didn't. Overall impression is a fantastic truck. I do dislike one thing and that could be a point of contention down the road. Needing all of those washers behiond the front arms could cause a hinge pin failure. I'd like to see a redesign where its more of an xb4 inner part of the arm, and xt2 outer part without the holes and gap to run on the XT2, also some harder front arms would be nice, but the mediums didnt take much away.
Old 06-29-2019, 07:36 PM
  #38
INFERN0's Avatar
Just finished the build. Looking for a bumpy loose dirt setup for this. Anyone have anything?
INFERN0 is offline
Old 06-30-2019, 01:48 AM
  #39
Use all of the medium plastics. Softer springs.
scoobyrs25 is offline
Old 06-30-2019, 06:36 AM
  #40
Anyone know if you’ll be able to run short course wheels on these like you can the ET410?
DapperDan is offline
Old 06-30-2019, 03:45 PM
  #41
Just guessing off the specs of how long the front/rear driveshafts are, yes you should be able to run sct wheels.
aspiringracer is offline
Old 07-01-2019, 04:33 PM
  #42
why would you cringe at titanium gears? Just curious.
MaX-D is offline
Old 07-16-2019, 12:11 PM
  #43
INFERN0's Avatar
I find titanium gears wear poorly and get sloppy.
INFERN0 is offline
Old 07-20-2019, 07:32 PM
  #44
Stealthpilot's Avatar
Xray noob here, just finished building my XT4 and was wondering a few things? Is the kit set-up more of a dirt or carpet set-up? Also I'm assuming with Xrays spring ratings the more "dots" the stiffer the springs? I'll be running mine on a 1/8 scale sized loose track running Jconcepts double d's tires, what do you guys suggest I pick up for the truck? smaller swaybars, softer springs..ect? Thanks in advance!
Stealthpilot is offline
Old 07-20-2019, 10:42 PM
  #45
Buy all of the medium flex plastics and soft springs.Center diff is great too.
