Team Associated B74 4wd buggy >
Like Tree301Likes
    Hide Wikipost
Old 08-14-2019, 10:03 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B74 4wd buggy
Last edit by: mes
B74 Manual
New parts list
Product page
petitrc set-up page
Pistons explained
B64 carry-over parts:
- front and rear wheels
- springs
- pistons
- plastic diff gears
- shock caps
- spring cups
- arm mount inserts
- ball cups
- wing
- clamping wheel hexes
- generic hardware, tools, fluids
Fan mounts:
Revolution Design Yokomo YZ-4SF Aluminium Fan Mount RDRP0474
Schelle B74 Fan Mount and Wire Clip SCH1444 (SCH1444-COMBO with Motiv fan)
Revolution Design B74 Fan Mount RDRP0495
Aluminum options:
front shock tower RDRP0496
rear shock tower RDRP0497
rear hub set RDRP0489
Gear chart:
Print Wikipost
Old 06-14-2019, 10:08 PM
  #361
Super Moderator
b1narych0ice's Avatar
Originally Posted by FastPete
Ok building myself one, instruction manual says shock eyelets, front long rear short. The supplemental instruction sheet says both long? I assume both long is correct?
Yes, book and Evans setup both use long eyelets all around.
b1narych0ice is offline
Old 06-14-2019, 10:29 PM
  #362
Super Moderator
Originally Posted by speed101
So does anyone know why they didn’t make the rear arms like the b6.1 shock location mounts
I think they are trying to really push durability on the new design, the rear arms on the 64 liked to break by the outer hinge pin and we have a new design there. 3 positions on the lower should be enough, and not having to make a wide tunnel for the insert should make the arm stronger.
No proof of this, just armchair car designing . I did traction roll a few times tonight and didn’t break yet, but I will keep the thread updated on my durability “research.”
Also, for the weight conscious, 1678g with a low profile battery. My 64 with pucks was 1660 with a regular shorty, so the new car needs a little diet... but it’s a rocket, my fastest b64 lap on our current layout was a 15.3 and I got down to 14.8 already with the fat new car. Not fat... big dogboned?
Old 06-14-2019, 10:38 PM
  #363
Super Moderator
And because we need more photos, here’s body off weight with a full size shorty.
Old 06-14-2019, 10:49 PM
  #364
mes
Consider it a set-up option. Both long should give you maximum droop and a very balanced car. If you want to reduce weight transfer from one end to the other, you can switch to the shorter ones. I think I might try short ones in the front today if my last changes (narrower hexes front vs rear) don't give me the amount of on-power steering I am looking for.
FastPete likes this.
mes is offline
Old 06-15-2019, 12:22 PM
  #365
Kepner's Avatar
Also really appreciate the new battery strap with a slot for the balance lead to facilitate in car charging. Always hated that about the stock 64 strap. With how fast these new batteries charge, you don't really need to swap batteries. I just blast my pro-teks at 15 amps and thats normally enough time between practice runs. Can always go to 30 amps if needed haha. (Charger limited).
Kepner is offline
Old 06-15-2019, 12:45 PM
  #366
mes
Today I managed to break the front shock tower between the shock and bulkhead mounting holes. The way it looks I guess that the cf layers have not bonded properly, but TBH something had to give. I got a whip totally wrong and the car was flying at high (mod) speed upside down and hit the floor with nothing but the shocks and shock tower. Other than that, the car took a lot of abuse again and was a dream to drive.
This is my preliminary astroturf set-up, enjoy!
File Type: pdf
jpcopeland1 and JeepnMike like this.
mes is offline
Old 06-15-2019, 03:56 PM
  #367
I'm just curious where this car is at for weight. Is it heavy or do you need to add
Racermac73 is offline
Old 06-15-2019, 05:46 PM
  #368
imprsme's Avatar
Trader Rating: 91 (100%+)
It’s on the Heavy side
imprsme is offline
Old 06-16-2019, 11:42 AM
  #369
Trader Rating: 166 (100%+)
when the team was up here in Oregon for the jconcepts carpet race, these cars took some serious tumbles, and came out noworse for wear, the yokomos..... not to much, so it’s durable. Glad to see ae up their duability game.
jpcopeland1 is offline
Old 06-17-2019, 07:33 AM
  #370
JeepnMike's Avatar
Trader Rating: 17 (100%+)
What are you guys doing with your receiver aerial/antenna wire? I usually run a 1-2" vertical tube under the body, but there is not a mount for it in this car.
JeepnMike is offline
Old 06-17-2019, 09:49 AM
  #371
If you have a vertical surface on your receiver you can CA glue a piece of fuel tubing and use that to mount your antenna tube. Not the most 'factory' solution but I suppose it would work.
JeepnMike likes this.
trf211 is offline
Old 06-17-2019, 10:28 AM
  #372
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Back when I used receivers with antenna, I either shoe Goo a tube onside the chassis or I coiled up the wire and shrink tubed it and taped to the side of the esc. For indoor racing, that is fine. If you are outdoor and a huge track, that might not work.
Wildcat1971 is offline
Old 06-17-2019, 10:50 AM
  #373
BRSracing's Avatar
Trader Rating: 67 (100%+)
https://www.shapeways.com/product/PR...ionId=80061787
BRSracing is offline
Old 06-17-2019, 03:52 PM
  #374
how/where do i get my hands on those!
Edwin Pibal is offline
Old 06-17-2019, 04:15 PM
  #375
FloridaST is offline
