MOTOR QUESTION
MOTOR QUESTION
guys,i have a TEAM ORION 17 TURN MOTOR ,my question is it comes with a blue wire and a yellow wire...i do not need to solder thes as i can just slip them on the motor,which wire is negative and which is positive?
The blue wire is intended to be the negative wire. On most speedos, the motor negative wire is the blue one as well...
Tony
Tony
Also, On the endbell of most motors, in the plastic they usually stamp a ( + ) in the end to signify which side is the positive.
thanks uys..i will check tonight.....the motor i have is the team orion havok 17 turn motor....
