Old 02-25-2006, 10:46 AM   #1
Default Nitro buggy won't Idle
Hi, I need some advice please!
I am very nice to Nitro and decided to pick up a cheap secon-hand buggy.
After a bit of work I managed to turn it over and the engine will start nicely. However, upon starting the engine (using the pullcord and Glowstart) the wheels spin - fast. There is no idling at all. Luckily I was attempting to get it to start using a block of wood so the wheels were off the ground.
Has anyone got an ideas? I am tempted to think that there is something wrong with the Clutch shoes/spring?
Look forward to your response
dan_allen_1 is offline   Reply With Quote
Old 02-25-2006, 11:05 AM   #2
save these and read they will help you on your nitro jerney have fun and good luck.
mgtman is offline   Reply With Quote
Old 02-25-2006, 12:15 PM   #3
Trader Rating: 36 (100%+)
If the wheels are spinning and the engine is revving, sounds to me like a bad clutch. Take the engine out, remove the flywheel nut and clutchbell. Check the shoes, springs and the bearings.
NitroOB4You is offline   Reply With Quote
Old 02-25-2006, 12:55 PM   #4
could be 100 other thing also like maybe you didnt have your radio on and it coused a run away then your tunning might be off maybe your idle is set wrong,your lsn might be off,your throthle epa might be off on the radio ,the list goes on
Nitro buggy experts: pls help to identify my buggy/determine resale value james559 Singapore R/C Racers 16 08-09-2008 09:12 PM
Can't get buggy to idle without engaging clutch bambooi Nitro Off-Road 11 08-20-2007 09:17 PM
Team Magic 1/8 M1 Nitro Buggy: the most advanced nitro buggy ever xakiat Singapore R/C Racers 12 08-18-2006 03:44 AM
rc10gt, idle probs. new 2 nitro parisherj Electric Off-Road 3 02-27-2006 04:19 PM
Help with Nitro Evader ST Idle mkimmer Electric Off-Road 6 02-25-2006 12:39 PM
SEO by vBSEO 3.5.0
