Brush in a tupperware setup
Hey all, I've seen almost everyone has a tupperware with a brush laid down inside and it's filled with water. I understand it's used to clean your tires but what type of brush (Hard/Soft) should be used for Soft/Slick (Running on clay).
Thanks...
Thanks...
https://www.amainhobbies.com/jconcep...2498-2/p535741
Awesome... Thanks....
BTW - I know alot of racers use simple green to clean the tires but what is used for the body , chasis, etc...
Simple green has changed, and it is no longer as good for the tires. I just use water to clean my tires.
I use an air compressor to keep my car clean, but from time to time I will use a 1 inch paint brush or old toothbrush. Lately I've been using citrus solvent for cleaning stuff that is stubborn or really dirty. $2 or so from the hardware store. Pledge or a light coat of WD-40 will make your car look clean.
How have you been a member here for so long, and never learned how to clean an rc car?
Get the Rubbermaid “brilliance” brand tub
It has the black rubber seal and black clips to hold tight.
it doesn’t leak and is air tight.
I just get a container tub big enough at the dollar store and a stiff but not to stiff bush, and cut the handle off and shoe goo it in never came unmounted after many uses cleans tires great ive used simple green / water on clay indoor tracks rarely outdoor.
A tire wash rig is just a brush glued into a container. Does the brush fit into the container? Really about it.
They had to change the chemical makeup of simple green back in 2013 for them to be able to call it "environmentally friendly". Even before 2013 they'd removed oil of wintergreen as an active ingredient. Oil of wintergreen is the ingredient that softens rubber (oil of wintergreen is used in some tire sauces too).
