Old 02-17-2006, 10:09 PM   #1
Send a message via AIM to Southpark8969
Default waterproofing gas trucks
is it possable too water proof your steering servo and the thottal servo?
if the is plz tell me
Southpark8969 is offline   Reply With Quote
Old 02-18-2006, 07:08 AM   #2
Trader Rating: 14 (100%+)
you really can't make your servo water proof - you can make it water resistant. Most high quality servos have an o ring where the case splits at the top and the bottom. Along with that, put some electrical tape around the case where they join together.
Most servos can get water and/or fuel on them with out malfunctioning, actually having them submerged in water is not how these were designed to work.
o.s. power is offline   Reply With Quote
Old 02-18-2006, 10:24 AM   #3
Trader Rating: 26 (96%+)
Do you wish to know for running purposes or cleaning purposes? Electronics can get water on them and still be fine if they are turned off. Once they get power if they are still wet they can malfunction. To seal up your reciever. Place it in a balloon and run the wires out the opening. Then fill the opening with silicone of some sort of filler that will keep it nice and h20 tight. I wouldn't water down your truck though just because the servo is very hard to keep water tight. Instead I would use denatured alchahol, an air compressor, and a airbrush. You can clean your car with the flow of air and denatured alchohol easily and it will dry off much faster then water will. Once its clean dry it with the air brush.
party_wagon is offline   Reply With Quote
Old 02-18-2006, 09:20 PM   #4
I would be worried about different stuff that servos if you want to run IN water.
cleaning should be fine. I use windex and air compressor to clean though.
MikeWO is offline   Reply With Quote
Waterproofing a Rustler parkerexx Rookie Zone 2 01-21-2008 11:05 PM
waterproofing a mamba max cm367700 Electric Off-Road 1 11-23-2007 05:56 AM
Waterproofing your receiver gearless Electric On-Road 11 02-04-2005 10:08 PM
waterproofing kh15 Electric On-Road 6 01-28-2005 05:52 PM
Waterproofing the motor gearless Electric On-Road 16 10-03-2004 04:46 PM
SEO by vBSEO 3.5.0
