Hate gluing tires? Check this out.
Hi all, thought I would try to contribute something useful to the forum. I don't know about you, but I've always hated gluing new tires with super glue. I always manage to get glue on my wheel and tire sidewall (which turns white and looks like crap). I also find it hard to seat the bead exactly right and have the tire perfectly even all around.
Using knowledge from another unrelated project, I found that using a special epoxy sticks to both plastic and rubber! By using an epoxy, you can take your damn sweet time to push the bead down evenly, wipe up any excess, and get it just right while it cures over the next 24 hours.
The only thing you should do is prep the bead and rim by roughing it up with sandpaper or scotchbrite, then cleaning with alcohol.
The epoxy is called 3M DP190. It comes in clear and gray. About $20 per tube, and would be enough to glue 3 to 5 sets of four wheels depending on the scale we're talking. I just did my first 1/10th scale wheels and they are solid!
Have you had any issues so far with it not holding or coming apart? I would be concerned about weight transfer as well? How well do the tires seem balanced? Thanks for tip I always hate super gluing my tires too.
Nothing beats a good CA glue seal. Just gotta practice, practice, practice.
Also, on tires that are smaller, fit the bead accordingly and glue just the connection where the rim and tire meet. I have been doing this to 1/10 2wd buggy tires with amazing success. They balance really good this way also. Just gotta make sure to use the little tip that comes with the bottle so that you only use as much as you minimally need to hold that connection. Also keeps the bead cleaner for reuse of the wheels if you need them for a second round. Then glue at the bead.
Thanks for sharing something new! We need more of this!
Another thing, for racers, epoxy is additional weight and causes more imbalance. Also, CA glue comes in various thicknesses / viscosity and setting times, so one can get what works, guven most tire CA's now are formulated for rubber and plastics. Years ago Tamiya used double sided sticky tape for its Foam F1 tires, that worked well, but since has faded into obscurity.
props on trying something new though. Just as a reminder to those that may be tempted, if you get your epoxy mixture wrong it wont set right, and wont dry.
Anyway, CA definitely has its advantages if you are skilled to do it right, otherwise this is another alternative that might also work for some people!
Worrying about the weight of the epoxy is drastically overthinking things.
The bond that CA glue makes is very very good. When you glue next to the tire/rim, does it turn the side of the tire white when it dries? Maybe it's just the glue I'm using, but it always seems to do that and looks terrible!
I'm not sure how much the weight of the epoxy will affect things realistically, but it certainly must weigh more than a thin layer of CA.
Shoe-goo was another option that people were using since it had some give to it when cured. Easily broken if needed and cutting it off the bead area of the wheels were easier than dried CA glue or epoxy.
That could be really nice. All the super glues I've tried end up sticking instantly, so if you make a small mistake it's already stuck down.
Anyone ever use E6000? I have some of that lying around and I've been using it on more and more non-RC related things. Curious if anyone has tried this.
I remember seeing a post at some point about non-RC products used in RC but can't find it. This post would be a great addition.
